Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Vb.net add-in wait cursor
5 REPLIES 5
AJK2010
1837 Views, 5 Replies
Can someone help me to show a wait-cursor in inventor?
I have a add-in without a form, and i want the cursor to change to the wait-cursor when my code is run.
Grz
kurt
5 REPLIES 5
xiaodong_liang
in reply to: AJK2010
AJK2010
in reply to: xiaodong_liang
I saw that thead, but the person who wrote that tread didn’t find a solution. I have already contacted him.
Can’t you give us the code we need to program this. I've already looked at InteractionEvents.SetCursor.
But I can’t figure out how this works.
Grz,
Kurt Cardinaels
xiaodong_liang
that guy just said he will try, but did not respond any more Can I assume he has solved it, but did not have time to get back to update? 🙂
anyway, the workflow to set cursor by InteractionEvents is: after you create InteractionEvents, call interactionEvents.SetCursor to load the built-in cursor type of Inventor, or the custom *.cur file. And start InteractionEvents.
I believe you have found the sample of InteractionEvents in API help doc. in case not, please just search by "Basic Selection Using Interaction Events API Sample".
But, I think this blog below may be of more helpful to you:
http://adndevblog.typepad.com/manufacturing/2012/05/how-to-set-custom-cursor-for-object-selection-us...
It's not clear in which context you want to set the cursor, ie: during an Inventor interaction or a custom workflow of your add-in... It's pretty straightforward to manipulate the cursor, see following thread:
http://stackoverflow.com/questions/1568557/how-can-i-make-the-cursor-turn-to-the-wait-cursor
Otherwise the link from Xiaodong should be useful for an Interaction Event in Inventor.
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
AJK2010 has indeed contacted me about this wait cursor problem. I didn't manage to get it working, but to be honest I didn't really try very hard. Because my code was running pretty long I decided to go with a simple wait form with a progress bar.
AJK2010, when you get this to work can you please post it in this topic? I would be very interested.
Best regards, Daniël
