as you can see me dilehma, i cant add custom values anymore. I dont understand this at all.
This looks like a personal/company tool, and not a basic Inventor tool. To help you, you need to provide this tool otherwise it's impossible to help you on this.
No need to supply anything just yet, it is a standard multi value parameter input box.
From the looks of it, the multi-value editor is expecting a number instead of text. It could possibly be that something is corrupt.
Maybe try deleting the parameter and re-creating it as a text parameter again, re-define it as multi-value and re-enter the values again.
What version of inventor are you using?
Re-doing the multiValue list did it. But Editing has the same results.
I'm using 2014 Inventor.
`Max
Sounds like an Autodesk issue (bug) , maybe update the service pack if it's available.
A workaround might be to try and populate the multi-value parameter via ilogic. Try see if that works. Also, try the same thing in a new part. Could be part (possibly corrupt) issue?
