Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
using apprentice to write iproperties interference from the Vault
1 REPLY 1
441 Views, 1 Reply
I am using an excel macro to open drawings for each part in an assembly and in the macro I am using apprentice to fill in custom iproperties in the drawing which fill out the release block that we use when we send a print to the floor.  This works great if the idw file is checked out from the vault.  however if it is not checked out apprentice cannont save the iproperties which means they aren't there when the drawing opens.  Is it possible to check out a part using apprentice?  Or maybe there is a better way to do this?  I would rethar not have to check out a drawing manualy and then fill in the i properties and then undo the check out after I print etc.
1 REPLY 1
Hello Mattr,
I cant help you with Vault but I'm interested to learn how to access iProperties with an Excel macro. Can you send me an example code snippet that can manage this?
