I have a VBA form coded that we use to generate part numbers and descriptions that then populate the iProperties. We often use the part sizes in the description. I would like to be able to put a button on the form that allows users to use the "Measure Distance" tool so that they can measure the part while they are creating the description.
Does anyone know code that I could use to activate the "measure" tool while a vba form is active?
Using Inventor 2012.
Thanks.
Hi benemt,
You should be able to run the Measure tool with the following code in VBA:
Sub Main()
Dim app As Inventor.Application
Set app = ThisApplication
Dim partDoc As PartDocument
Set partDoc = app.ActiveDocument
Dim oControlDef As ControlDefinition
Set oControlDef = app.CommandManager.ControlDefinitions.Item("AppMeasureDistanceCmd")
oControlDef.Execute
End Sub
Regards
Mitch
Let me know if it helps, Kudos if it works!
Thanks! This worked with one modification. Because I am using it within a user form, I need to Hide the user form while I execute the command in order to let the user take the measurement. Then, I show the form once the "Measure Distance" dialog box has been closed. This required the .Execute2(True) to be used. More info on Execute2 here: http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Private Sub cmdMeasure_Click()
frmWizard.Hide
oControlDef.Execute2 (True)
frmWizard.Show
End Sub
By default, the form is set to modal, if you change the behaviour of the form, you can measure without the need to deactivate the form
@Anonymous wrote:By default, the form is set to modal, if you change the behaviour of the form, you can measure without the need to deactivate the form
Another good idea, thanks Frederic!
Now that this is working very well, I would ideally like to be able to take the number found in the Measure Distance box and be able to insert it into my form. Based on what I've read about running these sorts of commands using the API, I don't think I can get access to this information but I figured I would throw it out there to see if anyone has an idea on that one.
Hi benemt,
I haven't worked with these yet, but I believe what you're looking for are the "Attributes" of the part. If I'm understanding correctly as I read through threads every so often, you can programmically access lengths this way. There would also be no need to measure the line manually.
I'm not sure if you know which distance you'd like to measure beforehand, or if it is completely dependant on what the user would like.
Again, I haven't worked with these yet and not even sure if I'm on the right track, but I would start there if it helps you.
Regards
Mitch
@Anonymous wrote:Hi benemt,
Regards
Mitch
Interesting thought, Mitch. Thanks. It is dependent on what the user would like but I could populate a list of dimensions in the part for them to pick from. I think I will let this idea sit on the shelf for now and possibly develop it for the next update once I've been able to think about it for a bit.
And the help sample file???
Public Sub InteractiveMeasureDistance() ' Create a new clsMeasure object. Dim oMeasure As New clsMeasure ' Call the Measure method of the clsMeasure object Call oMeasure.Measure(kDistanceMeasure) End Sub Public Sub InteractiveMeasureAngle() ' Create a new clsMeasure object. Dim oMeasure As New clsMeasure ' Call the Measure method of the clsMeasure object Call oMeasure.Measure(kAngleMeasure) End Sub '************************************************************* ' The declarations and functions below need to be copied into ' a class module whose name is "clsMeasure". The name can be ' changed but you'll need to change the declaration in the ' calling function "InteractiveMeasureDistance" and ' "InteractiveMeasureAngle" to use the new name. ' Declare the event objects Private WithEvents oInteractEvents As InteractionEvents Private WithEvents oMeasureEvents As MeasureEvents ' Declare a flag that's used to determine when measuring stops. Private bStillMeasuring As Boolean Private eMeasureType As MeasureTypeEnum Public Sub Measure(MeasureType As MeasureTypeEnum) eMeasureType = MeasureType ' Initialize flag. bStillMeasuring = True ' Create an InteractionEvents object. Set oInteractEvents = ThisApplication.CommandManager.CreateInteractionEvents ' Set a reference to the measure events. Set oMeasureEvents = oInteractEvents.MeasureEvents oMeasureEvents.Enabled = True ' Start the InteractionEvents object. oInteractEvents.Start ' Start measure tool If eMeasureType = kDistanceMeasure Then oMeasureEvents.Measure kDistanceMeasure Else oMeasureEvents.Measure kAngleMeasure End If ' Loop until a selection is made. Do While bStillMeasuring DoEvents Loop ' Stop the InteractionEvents object. oInteractEvents.Stop ' Clean up. Set oMeasureEvents = Nothing Set oInteractEvents = Nothing End Sub Private Sub oInteractEvents_OnTerminate() ' Set the flag to indicate we're done. bStillMeasuring = False End Sub Private Sub oMeasureEvents_OnMeasure(ByVal MeasureType As MeasureTypeEnum, ByVal MeasuredValue As Double, ByVal Context As NameValueMap) Dim strMeasuredValue As String If eMeasureType = kDistanceMeasure Then strMeasureValue = ThisApplication.ActiveDocument.UnitsOfMeasure.GetStringFromValue(MeasuredValue, kDefaultDisplayLengthUnits) MsgBox "Distance = " & strMeasureValue, vbOKOnly, "Measure Distance" Else strMeasureValue = ThisApplication.ActiveDocument.UnitsOfMeasure.GetStringFromValue(MeasuredValue, kDefaultDisplayAngleUnits) MsgBox "Angle = " & strMeasureValue, vbOKOnly, "Measure Angle" End If ' Set the flag to indicate we're done. bStillMeasuring = False End Sub
Thanks again Frederic. I'm quite busy right now but I will try this out as soon as I get a bit of time. Based on what I had read, I thought I was going to need more of a workaround so I didn't even think to look at the help file.
