This sounds like a silly question at first, but is there a way to use the form buttons in the "Forms" or "Global Forms" tabs without having to see the actual form? I.e. can I use a form button to trigger a rule directly?
This is to avoid having to go into Rules/External Rules, find the rule, right click it and run - instead I would have some "Rules" run by form buttons from those tabs instead. Is this doable?
Solved by LukeDavenport. Go to Solution.
You can start a rule from a form button.
You can suppress the rule in the tree and fire it from a form button, only when you need it... but you have to open the form where is the button...
Yeah I would like to be able to skip opening the form, or somehow make it an invisible operation if possible.
Well, both yes and no. It does what I already know, to make a form with a button to launch a rule. I want the rule to execute immediately when pressing the button in the "Forms" tab, without having to interact with a dialog box, just to save a step. This doesn't seem possible as far as anyone has been able to tell me this far. Its just a small thing to skip an unnecessary step in some cases.
Hi TommySWE,
Did you read the blog properly? I think it describes exactly what you are looking for - you can click a button on the 'forms' tab which will activate a rule not a form.
Luke
