Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
upgrade frustrations......
2 REPLIES 2
NachitoMax
167 Views, 2 Replies
why why why do you insist on changing things that are not broken when you should really apply your time on trhings that need fixing??
Problem:
this worked just fine in 2013
Dim oFileLocations As FileLocations
    Set oFileLocations = ThisApplication.FileLocations
            Dim FolderPath As String
            FolderPath = oFileLocations.Workspace
            Shell "explorer.exe" & " " & FolderPath & "", vbNormalFocus
 it allowed us to open the current project folder instead of ardulously trawling through the server the get to the folder
in 2015, ThisApplication.FileLocations doesnt even exist! why?
on the other hand, Presentation files still continue to randomly remove the textures all on their own without any changes being made to assemblies or parts.
fix what needs fixing, leave what works just fine.
Can you please direct me to the alternaive for FileLocations?
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
2 REPLIES 2
pball
in reply to: NachitoMax
Your code works perfectly for me in 2015. I have a few functions that use ThisApplication.FileLocations without issue. It seems you might have another issue outside of that code.
edit:
wow my english is horrible this morning
NachitoMax
in reply to: pball
hmmmmm i got errors on every tool at the point of declariing as FileLocation.
not to worry, i have created a workaround anyway by truncating the filename 🙂
Cheers
Nigel
Nacho
