Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Unhandled Exception while setting the Minitoolbar.Position Property
1 REPLY 1
Frederik_Mussler
511 Views, 1 Reply
i have a really strange problem, because this code works at some pc's and on some not.
I'm using Inventor 2013 SP 1.1 with Update 2 on Windows 7 64-Bit. All Windows and .NET Updates installed.
Option Explicit On
Imports Inventor
Public Class Form1
    Dim oApp As Inventor.Application
    Private WithEvents m_miniToolbar As MiniToolbar
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
    End Sub
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        m_miniToolbar = oApp.CommandManager.CreateMiniToolbar
        Dim controls As MiniToolbarControls
        controls = m_miniToolbar.Controls
        controls.AddButton("MyButton1", "Winkel", "This is button 1")
        Dim m_p As Inventor.Point2d = oApp.TransientGeometry.CreatePoint2d(20, 100)
        m_miniToolbar.Position = m_p
        m_miniToolbar.Visible = True
    End Sub
End Class
The exeption is thrown at the line "m_miniToolbar.Position = m_p"
I'm sorry, i can just provide the german error message, but here is my translation:
An unhandled exception of the type "System.Runtime.InteropServices.COMException" in mscorlib.dll has occured.
Additional Information: Unspecified error (Exception HRESULT: 0x80004005 (E_FAIL))
See the screenshot in the attachments
Stack Trace:
System.Runtime.InteropServices.COMException wurde nicht behandelt.
  ErrorCode=-2147467259
  HResult=-2147467259
  Message=Unbekannter Fehler (Ausnahme von HRESULT: 0x80004005 (E_FAIL))
  Source=""
  StackTrace:
       bei System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
       bei Inventor.MiniToolbarObject.set_Position(Point2d Param)
       bei WindowsApplication1.Form1.Button1_Click(Object sender, EventArgs e) in C:\Users\Frederik\AppData\Local\Temporary Projects\WindowsApplication1\Form1.vb:Zeile 24.
       bei System.Windows.Forms.Control.OnClick(EventArgs e)
       bei System.Windows.Forms.Button.OnClick(EventArgs e)
       bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       bei System.Windows.Forms.Control.WndProc(Message& m)
       bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
       bei System.Windows.Forms.Button.WndProc(Message& m)
       bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       bei System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       bei System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       bei System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
       bei System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       bei System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       bei System.Windows.Forms.Application.Run(ApplicationContext context)
       bei Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun()
       bei Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel()
       bei Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine)
       bei WindowsApplication1.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:Zeile 81.
       bei System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args)
       bei System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       bei Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       bei System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       bei System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
       bei System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       bei System.Threading.ThreadHelper.ThreadStart()
  InnerException:
1 REPLY 1
Do you have the same installations (same version of Inventor, Visual Studio, etc.) also on machines on which you can reproduce this issue? Is this issue dataset specific? Do you get the same result with/without Inventor addins loaded?
I am asking because I was not able to reproduce it so far...
Jan
