Thread form data spread sheet. thread.xls UN, AMSI Metric, BA, BSF, BSW, British Standard Witworth, ISO Metric, ISO Metric Trapezoidal Threads, Inch Tapping Threads, Metric Forming Screw Threads, NPSH, NPT for PVC Pipe and Fitting, NPT, ISO Pipe Threads,ISO Taper Internal, JIS Pipe Threads, JIS Taper, JIS Taper Internal, Din Taper, DIN Pipe Taper, DIN Pipe Taper Internal, DIN Pipe Threads, BSP Pipe Threads, BSP Taper, BSP Taper Internal, GB Metric profile, GB Pipe Threads without seal, AFBMA Standard Locknuts, GOST Self-tapping Screw Thread, Metric HeliCoil, and UN HeliCoil.
Past the attached Spread sheet to:
C:\Users\Public\Documents\Autodesk\Inventor 2015\Design Data\XLS\en-US
You'll have all the thread detail mentioned above.
The British Association on this sheet works.
Alternatively, you can copy exserts to imbelish your exsisting spread sheet. Just create a new sheet in your exsisting thread.xls and past in what you need.
Hope my sheet helps you out.
D.
