Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Turning off visibility for all levels of components in Assembly
1 REPLY 1
240 Views, 1 Reply
I have an iLogic rule that will turn off the visibility of parts based on user input, but will only turn off the subassemblies/parts that are 1st level parts.  I would like to have the rule turn off all instances of a specified part within an assembly.  In other words, I need a way to modify the code shown below so it will recognize the instances of the components in the subassemblies as well.
 ' Define User input
uPrefix = InputBox("What is Prefix?","Prefix","n/a")
PreLen = Len(uPrefix)
' Define a variable to the open Assembly Components
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all occurrences and turn off specified parts
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
   If (Left(oOccurrence.Name,PreLen) = uPrefix) Then
      Component.Visible(oOccurrence.Name) = False
Next
Daniel
1 REPLY 1
adam.nagy
HI Daniel,
If you are ony interested in parts, then you could simply replace in your code
with
oAsmCompDef.Occurrences.AllLeafOccurrences
Otherwise you could iterate through all the occurrences and suboccurrences using a recursive function like the TraverseAssemblySample() in this blog post:
http://modthemachine.typepad.com/my_weblog/2009/03/accessing-assembly-components.html
Cheers,
Adam Nagy
Autodesk Platform Services
