Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Turn on/off layer text in each sheet
3 REPLIES 3
GosponZ
415 Views, 3 Replies
Our drawings are  multi sheets. In title block is some text that we do not need on all sheets. My question is it possible to turn on/off text in title block for each sheet.If i have text in one sheet but not in few others.
I have rule where i can turn on/off layer with specific text in title block but only problem is if i do so then i turn off text in all sheets. Can you guys help?
Thanks!
3 REPLIES 3
Vladimir.Ananyev
in reply to: GosponZ
TextBox object has Layer property that gets and sets the layer associated with this object.
So you may create special Layer for “invisible” TextBoxes and move desired TextBox object to this layer at any moment.
See also  “Moving sketch entities to a new layer API Sample “ in the Inventor API Help.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
GosponZ
in reply to: Vladimir.Ananyev
I did try but with no success. Do you have any iLogic code that i could use?
Vladimir.Ananyev
Texts are turned on/off in all sheets because all these sheets use TitleBlock objects with the same TitleBlockDefinition.  If you are able to create several TitleBlock definitions that differ by some text visibility you may programmatically (via iLogic rule) replace the current TitleBlock by another one with different definition.
Inventor API Help provides several code samples for TitleBlockDefinition Object:
  • TitleBlockCopy
  • InsertTitleBlockOnSheet
  • CreateTitleBlockDefinition
Vladimir Ananyev
