Inventor Customization
Member
0 Kudos
Post 1 of 8
Turn off Translucent using VBA
761 Views, 7 Replies
11-10-2011 08:36 PM
Hi All,
I'm trying to make a translucent part file to a opaque part file by using the below code
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    oDocument.ActiveRenderStyle.Opacity = 1    'making the body opaque
But it doesnot help.Can someone please let me know how to do it through code.
PS: attached is the process of doing it manually
Thank You
Like this?
Public Sub TranslucentTest()
Dim app As Inventor.Application
Set app = ThisApplication
Dim partDoc As PartDocument
Set partDoc = app.ActiveDocument
Dim oWorkSurface As WorkSurface
Set oWorkSurface = partDoc.ComponentDefinition.WorkSurfaces.Item(1)
oWorkSurface.Translucent = False
End Sub
Valued Mentor
11 Kudos
Post 2 of 8
Re: Turn off Translucent using VBA
11-12-2011 07:19 AM in reply to: rrdeveloper
Like this?
End Sub
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
Member
0 Kudos
Post 3 of 8
11-13-2011 07:40 PM in reply to: JohanLarsson
Thank You.
I works as expected :womanvery-happy:
Active Member
1 Kudo
Post 4 of 8
03-14-2012 07:40 AM in reply to: JohanLarsson
This works for part docs only, is there any way we can improve upon this to change all part surfaces in an assembly file instead of opening each part that has a surface individually?
Member
0 Kudos
Post 5 of 8
03-14-2012 08:47 PM in reply to: jalexander
        Dim oModel As AssemblyDocument
        Set oModel = ThisApplication.ActiveDocument '.iam file
        'or open the assembly file as below
        'Set oModel = ThisApplication.Documents.Open("D:\TestAssm.iam", False)
       'then identify each part in the assembly & set the surface to opaque
      For i = 1 To oModel.ComponentDefinition.Occurrences.Count
       Set partDoc = oModel.ComponentDefinition.Occurrences.Item(i).Definition.Document
       Next
End Sub
The above code identifies each part in the assembly & changes its surface
Hope this helps
1 Kudo
Post 6 of 8
09-26-2014 07:45 AM in reply to: rrdeveloper
I tried it,
I have inventor 2012
 got an error
Runtime error '-2147467259 (80004005)':
Method 'Item' of object 'WorkSurfaces' failed
it highlighted
any suggestions?
1 Kudo
Post 7 of 8
09-26-2014 07:59 AM in reply to: dwweekly
I found that it does not work in multiple sub assemblies, is there a change in code to go down thru multiple assemblies?
1 Kudo
Post 8 of 8
09-26-2014 08:01 AM in reply to: dwweekly
also it hangs on solid models...I think
