Turn off Translucent using VBA
9 REPLIES 9
Message 1 of 10
1662 Views, 9 Replies
Hi All,
I'm trying to make a translucent part file to a opaque part file by using the below code
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    oDocument.ActiveRenderStyle.Opacity = 1    'making the body opaque
But it doesnot help.Can someone please let me know how to do it through code.
PS: attached is the process of doing it manually
Thank You
Tags (1)
9 REPLIES 9
Message 2 of 10
JohanLarsson
Like this?
Public Sub TranslucentTest()
    Dim app As Inventor.Application
    Set app = ThisApplication
    Dim partDoc As PartDocument
    Set partDoc = app.ActiveDocument
    Dim oWorkSurface As WorkSurface
    Set oWorkSurface = partDoc.ComponentDefinition.WorkSurfaces.Item(1)
    oWorkSurface.Translucent = False
End Sub
Inventor Professional 2012 SP1 (25 seats with subscription)
Windows 7 64 bit
Lenovo D20, 12 GB RAM, Intel Xeon X5687 3.6 GHz, SSD
Quadro 4000, driver 8.17.12.9573, dual monitors
SpacePilot, driver version 6.15.3 Firmware 3.12
Message 3 of 10
in reply to: JohanLarsson
Thank You.
I works as expected Woman Very Happy
Message 4 of 10
jalexander
This works for part docs only, is there any way we can improve upon this to change all part surfaces in an assembly file instead of opening each part that has a surface individually?
Tags (2)
Message 5 of 10
in reply to: jalexander
        Dim oModel As AssemblyDocument
        Set oModel = ThisApplication.ActiveDocument '.iam file
        'or open the assembly file as below
        'Set oModel = ThisApplication.Documents.Open("D:\TestAssm.iam", False)
       'then identify each part in the assembly & set the surface to opaque
      For i = 1 To oModel.ComponentDefinition.Occurrences.Count
       Set partDoc = oModel.ComponentDefinition.Occurrences.Item(i).Definition.Document
       Next
End Sub
The above code identifies each part in the assembly & changes its surface
Hope this helps
Message 6 of 10
dwweekly
I tried it,
I have inventor 2012
 got an error
Runtime error '-2147467259 (80004005)':
Method 'Item' of object 'WorkSurfaces' failed
it highlighted
any suggestions?
Message 7 of 10
dwweekly
in reply to: dwweekly
I found that it does not work in multiple sub assemblies, is there a change in code to go down thru multiple assemblies?
Message 8 of 10
dwweekly
also it hangs on solid models...I think
Message 9 of 10
sebastien.forman
Please find my code with recursive functionality.
Public Sub TranslucentToOpaqueAllParts()
    Dim oModel1 As AssemblyDocument
    Set oModel1 = ThisApplication.ActiveDocument
    TranslucentToOpaqueAllPartsRecurcivePart oModel1
End Sub
Private Sub TranslucentToOpaqueAllPartsRecurcivePart(oModel As AssemblyDocument)
    Dim partDoc As Document
                If partDoc.DocumentType = kPartDocumentObject Then
                Else
                    changeInIamToOpaque partDoc
                End If
        Next
End Sub
Message 10 of 10
Stooie
in reply to: sebastien.forman
Obvious, Itinerant every surface.
End Sub
For Each oWorkSurface In partDoc.ComponentDefinition.WorkSurfaces
Next
Else
'changeInIamToOpaque partDoc
End If
Next
End Sub
