Inventor Customization
krieg
Message 11 of 19 (155 Views)
Re: Trying to use "GetPromptTextValues" method
01-08-2013 01:06 PM in reply to: dave.deane
Hello
I see the video, but can't believe what I see. I'm using the same code (with removed i=i+1, that's correct in your code), open a new Inventor-dwg, insert block "BRA" from your template file, fill out some attributes, run the code and get attributes and values. Please see attached Screenshots in zipfile.
I'm using Inventor 2013 SP1.1 Update 1.
Sorry, I'm running out of ideas what's going wrong.
Valued Contributor
dave.deane
Message 12 of 19 (146 Views)
01-09-2013 11:28 AM in reply to: krieg
I am using Inventor Professional 2013 sp1.1 64 bit xp pro
I also have Inventor 2013 sp1.1 (non professional) on 32 bit xp pro. It doesn't work on either.
In your code did you have sTags dim as strings or objects? Any chance you can upload the .exe to see if your working build works on this end?
A support case has been logged at Autodesk. Hopefully, I will get this sorted out.
Thank you again,
Dave
krieg
Message 13 of 19 (142 Views)
01-09-2013 01:20 PM in reply to: dave.deane
Hello
sTags and sValues are defined as String. I have counted the attributes and found 23. So:
Dim sTags(23) As String
Dim sAttr(23) As String
 I attached the exe and if this works on your site, I can send you my project. Maybe there's a difference we both don't registred yet.
Please replace the extension txt with exe.
Valued Contributor
dave.deane
Message 14 of 19 (138 Views)
01-09-2013 01:34 PM in reply to: krieg
It doesn't work. I get an array error, screenshot below.
I hope autodesk support can save me on this one. I don't know what else to do.
krieg
Message 15 of 19 (132 Views)
01-09-2013 01:40 PM in reply to: dave.deane
Hello
Sorry couldn't help you. My best wishes Autodesk can help.
ADN Support Specialist
xiaodong.liang
Message 16 of 19 (126 Views)
01-10-2013 09:52 PM in reply to: dave.deane
I discussed with our engineer and we did some tests. The following code can work. Not much change than the code Krieg provided in message 9. Could you give it a try?
  PrivateSub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        ' Connect to a running instance of Inventor.
        Dim invApp As Inventor.Application
        ' Check to see if a drawing is active
        invApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        If invApp.ActiveDocument.DocumentType <> Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            MsgBox("Need to have a drawing document active")
            Return
        EndIf
        ' Create ref to active drawing document
        Dim oDrawingDoc As Inventor.DrawingDocument
        oDrawingDoc = invApp.ActiveDocument
        ' Create ref to AutoCADBlocks collection in the active sheet
        Dim cAcadBlocks As Inventor.AutoCADBlocks
        cAcadBlocks = oDrawingDoc.ActiveSheet.AutoCADBlocks
        ' Set the name of the block
        Dim AcadBlockName AsString
        AcadBlockName = "BRA"
        ' Create ref to the AutoCAD block object in the active sheet
        Dim oAcadBlock As Inventor.AutoCADBlock
        oAcadBlock = cAcadBlocks.Item(AcadBlockName)
        ' check to see if block object code is working (it does)
        Debug.Print(oAcadBlock.Scale)
        Debug.Print(oAcadBlock.LineWeight)
        Debug.Print(oAcadBlock.Name)
        Debug.Print(oAcadBlock.AttributeSets.Count)
        'XXXXXXXXXXXXXXXXXXXX FAILS BELOW XXXXXXXXXXXXXXXXXXXXX
        ' Try and display block tags and values
        'correct
        Dim sTags() AsString = NewString() {}
        Dim sAttr() AsString = NewString() {}
        'wrong
        'Dim sTags() As String = New Object() {}
        'Dim sAttr() As String = New Object() {}
        'correct only when  the count of texts
        ' are no more than 23
        'Dim sTags(23) As String
        'Dim sAttr(23) As String
        'wrong
        oAcadBlock.GetPromptTextValues(sTags, sAttr)
        Dim i AsInteger
        Dim iCount AsInteger
        iCount = UBound(sTags)
        Debug.Print("icount = " & iCount)
        ' display attribute tag and value
        For i = 0 To iCount
            MsgBox(sTags(i) & " = " & sAttr(i))
            i = i + 1
        Next
    EndSub
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
Valued Contributor
dave.deane
Message 17 of 19 (116 Views)
01-11-2013 05:57 AM in reply to: xiaodong.liang
Xiaodong,
It will not build as posted. Intellisense does not like AsString, Once I separate the words it then doesn't like the empty squiggly brackets at the end. Please see screen shot below.
krieg
Message 18 of 19 (106 Views)
01-11-2013 02:31 PM in reply to: dave.deane
Hello
Try it in this way
Dim sTags() As String = New System.String() {}
Valued Contributor
dave.deane
Message 19 of 19 (100 Views)
01-14-2013 06:58 AM in reply to: krieg
Winner, Winner! ....... It builds and works! Thank you Krieg and Xiadong.
Is this just part of the learning curve or is there some reading references I need to study? I'm not sure how I would have ever figured this out. I can't find any meaningful syntax explantion searching the web for this. What purpose does the "{}" do? I'm just wondering out loud why a "regular" string array does not work for me but it did for you Krieg?
Onward with the rest of my program development.
Thank you again,
Dave
Announcements
Need installation help?
