Trying to use AddByProjectingEntity with a DrawingSketch
4 REPLIES 4
larry.daubenspeck
1595 Views, 4 Replies
Help!  I am trying to project geometry (a floor plan) onto a DrawingSketch using the AddByProjectingEntity method.  The active document is a Drawing; I have created the DrawingSketch from the active view.  Yet nothing I try seems to work.  Can it really be that difficult?  A sample of one of my attempts follows.  What am I missing?
'Get the drawing document.
Dim thisDwg As DrawingDocument = InvApp.ActiveDocument
'Get the sheet.
Dim thisSheet As Sheet = thisDwg.ActiveSheet
'Get the active view.
Dim thisView As DrawingView = thisSheet.DrawingViews.Item(1)
'Create a sketch.
Dim thisDwgSketch As DrawingSketch = thisView.Sketches.Add
'Start editing the sketch.
thisDwgSketch.Edit()
'Get the referenced assembly document.
Dim AssyDoc As AssemblyDocument = thisView.ReferencedDocumentDescriptor.ReferencedDocument
Dim AssyCompDef As AssemblyComponentDefinition = AssyDoc.ComponentDefinition
Dim Backstop1 As ComponentOccurrence = AssyCompDef.Occurrences.Item(1)
Dim Gym1 As ComponentOccurrence = Nothing
For Each Gym1 In Backstop1.Definition.Occurrences
     If InStr(Gym1.Name, "GYM") Then
          Exit For
     End If
Next
Dim oOccur As ComponentOccurrence = Nothing
For Each oOccur In Gym1.Definition.Occurrences
     If InStr(oOccur.Name, "WALLS") Then
          For Each SurfBody As SurfaceBody In oOccur.SurfaceBodies
               For Each oEdge As Edge In SurfBody.Edges
                    Dim anObject As Object = Nothing
                    oOccur.CreateGeometryProxy(oEdge, anObject)
                    thisDwgSketch.AddByProjectingEntity(anObject)
               Next
          Next
          Exit For
     End If
Next
thisDwgSketch.ExitEdit()
Larry Daubenspeck
Software Programmer
Draper, Inc.
4 REPLIES 4
ekinsb
in reply to: larry.daubenspeck
When using the AddByProjectingEntity method in a drawing you need to provide an entity that exists in the context of a drawing.  You were getting the edge in the context of the assembly.  The object that represents an edge in the drawing is a DrawingCurve object.  I converted your program to VBA because it's quicker to test and modified it to work.  In my test I had a simple assembly with two parts where one of them is named "BoxInPocket".  It looks for this part and then projects all of its edges onto the newly created sketch.
Public Sub ProjectEntity()
    Set thisDwg = ThisApplication.ActiveDocument
    'Get the sheet.
    Set thisSheet = thisDwg.ActiveSheet
    Set thisView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, _
                                                    "Select the drawing view.")
    'Create a sketch on the view.
    Set thisDwgSketch = thisView.Sketches.Add
    ' Get the referenced assembly.
    Dim asmDoc As AssemblyDocument
    Set asmDoc = thisView.ReferencedDocumentDescriptor.ReferencedDocument
    ' Get the occurrence named "BoxInPocket"
    Dim boxOcc As ComponentOccurrence
    For Each boxOcc In asmDoc.ComponentDefinition.Occurrences
        If InStr(boxOcc.Name, "BoxInPocket") Then
            ' Iterate over the the edges in the part.
            ' Since the surface body is obtained from the occurence
            ' it is a SurfaceBodyProxy and will return proxy edges
            ' in the context of the top-level assembly.
            Dim partEdge As Edge
            For Each partEdge In boxOcc.SurfaceBodies.Item(1).Edges
                ' Attempt to get any drawing curves associated with this edge.
                ' This will return curves if the edge is visible in the view.
                Dim drawCurves As DrawingCurvesEnumerator
                Set drawCurves = thisView.DrawingCurves(partEdge)
                ' Project each drawing curve onto the sketch.
                Dim drawCurve As DrawingCurve
                For Each drawCurve In drawCurves
                    Dim ent As SketchEntity
                    Set ent = thisDwgSketch.AddByProjectingEntity(drawCurve)
                Next
            Next
        End If
    Next
End Sub
Brian Ekins
Mod the Machine blog
larry.daubenspeck
in reply to: ekinsb
Thanks Brian,
I got your version to work fine, both in VBA and Vb.net.  Mine, however, is still telling me that my parameter is incorrect when it gets to this line:
     Dim drawCurves As DrawingCurvesEnumerator = thisView.DrawingCurves(oEdge)
The only difference that I can tell is that the part I'm wanting to project is a few levels deep into the assembly, whereas yours is a top-level part.  Could that be making a difference?
Larry Daubenspeck
Software Programmer
Draper, Inc.
Hi Larry,
yes, you will have to recurse the sub assembly to get the part. The following code is for you reference.
    'Get the sheet.
    'For Each boxOcc In asmDoc.ComponentDefinition.Occurrences
        If InStr(boxOcc.Name, "Assembly1:1") Then
             Call recurse_occ(boxOcc, thisView, thisDwgSketch)
        End If
    Next
End Sub
Sub recurse_occ(oParentOcc As ComponentOccurrence, thisView As DrawingView, thisDwgSketch As DrawingSketch)
    If TypeOf oParentOcc.Definition Is PartComponentDefinition Then
                For Each partEdge In oParentOcc.SurfaceBodies.Item(1).Edges
                    Next
                Next
             Else
               ' if this occurrence is a sub assembly
                Dim oSubOcc As ComponentOccurrence
                For Each oSubOcc In oParentOcc.SubOccurrences
                    Call recurse_occ(oSubOcc, thisView, thisDwgSketch)
                Next
            End If
End Sub
You can also get all referenced documents of the top assembly by AllReferencedDocuments, check which are part, and add the project sketch (similar code above) for them in the drawing.
Thanks Xiaodong,
I finally got it to work, but not as I expected.
Initially, I searched through the top level assembly to find a particular backstop, and then searched through the backstop to find its gym, and then searched through the gym to find the walls.  This, however, was resulting in an "incorrect parameter" error.
I then modified your method to recursively search, starting at the top, and continue through everything until I arrived at a part with the name I was looking for.  Doing it this way worked.  Not sure why, but at least I can continue on now.
Thanks again.
Larry Daubenspeck
Software Programmer
Draper, Inc.
