Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Trying to extract the view index from a for each of drawing views.
1 REPLY 1
229 Views, 1 Reply
I'm trying to cycle through all of the drawing views in an IDW, grab both the elevation and bottom view (there are many of each), and push those into a Call to another Sub. The two views will always be aligned vertically, and the index numbers of each pair of views are always one number off (The first pair have item indices of 1 and 2 respectively). Is this possible? I'm still trying different approches to this problem, but can't seem to find where the index value for each Item in ThisApplication.ActiveDocument.ActiveSheet.DrawingViews can be found. Either that or reference one from the other, and then assign the referenced one to a DrawingView instance. Here's a little of what I'm playing with:
Dim oDraw As DrawingDocument
Set oDraw = ThisApplication.ActiveDocument
Dim oSheet As sheet
Set oSheet = oDraw.ActiveSheet
Dim oView As DrawingView
Dim oBottomView As DrawingView
Dim oChartSize As Double
Dim oPoint As Point2d
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
For Each oView In oSheet.DrawingViews
If oView.Name = "ELEVATION VIEW" Then
(INSERT AMAZING, WONDERFUL CODE HERE)
Call ScaleViews(oView, oBottomView, oChartSize, oPoint, oSheet)
End If
Next
Mike
1 REPLY 1
I think I figured out a way to do this. It's not rock solid, but I think it will work until I can find a better way:
Dim oSheet As sheet
Dim oElevationView As DrawingView
For i = 1 To oSheet.DrawingViews.Count
Set oElevationView = oSheet.DrawingViews.Item(i)
If oElevationView.Name = "ELEVATION VIEW" Then
Set oBottomView = oSheet.DrawingViews.Item(i + 1)
If oBottomView.Name = "BOTTOM VIEW" Then
Call ScaleViews(oElevationView, oBottomView, oChartSize, oPoint, oSheet)
Else
uselessVariable = MsgBox("Cannot find related BOTTOM VIEW", vbOKOnly, "Error!")
End If
End If
Next
I guess taking the time to formulate my thoughts into a post was enough to get my brain back to "normal". Yea!
If anyone has any other thoughts, I am always interested in other approaches!
Mike
