Just a quick one which I can't seem to find the answer for (perhaps I am using the wrong keywords?). When you generate facets of a SurfaceBody using the Inventor API, are the triangles in the mesh guaranteed to have a particular winding? ie will they always be listed in a specific rotation with respect to the triangle normal?
Also, are the vertex normals generated always guaranteed to be outward facing by default? I understand this is the convention for meshes in general, but I'm not sure if Inventor does it.
Thanks!
Solved by ekinsb. Go to Solution.
Inventor follows the standard conventions.
so does that mean normals always outward, vertex winding counterclockwise?
Yes, normals will always point out when the mesh was generated from a solid. If the mesh was generated from a surface, there isn't an "out" direction but it will be arbitrary and all of triangles in the mesh will be consistent. The vertex winding is also consistent and is counterclockwise.
