Triangle mesh winding of facets from the Inventor API
4 REPLIES 4
jeremy.herbert
474 Views, 4 Replies
Just a quick one which I can't seem to find the answer for (perhaps I am using the wrong keywords?). When you generate facets of a SurfaceBody using the Inventor API, are the triangles in the mesh guaranteed to have a particular winding? ie will they always be listed in a specific rotation with respect to the triangle normal?
Also, are the vertex normals generated always guaranteed to be outward facing by default? I understand this is the convention for meshes in general, but I'm not sure if Inventor does it.
Thanks!
4 REPLIES 4
ekinsb
in reply to: jeremy.herbert
Inventor follows the standard conventions.
Brian Ekins
Mod the Machine blog
jeremy.herbert
in reply to: ekinsb
so does that mean normals always outward, vertex winding counterclockwise?
ekinsb
Yes, normals will always point out when the mesh was generated from a solid.  If the mesh was generated from a surface, there isn't an "out" direction but it will be arbitrary and all of triangles in the mesh will be consistent.  The vertex winding is also consistent and is counterclockwise.
Brian Ekins
jeremy.herbert
in reply to: ekinsb
Perfect. Thank you!
