Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Trap first sketch dimension
1 REPLY 1
228 Views, 1 Reply
Is it possible to trap the first created sketch dimension of a part and interogate it?
If so, what do I need to use?
Thanks in advance, Dave
1 REPLY 1
Sub CheckFirstDimension()
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oPartDoc.ComponentDefinition
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches(1)
Dim oFirstDimension As DimensionConstraint
Set oFirstDimension = oSketch.DimensionConstraints(1)
Debug.Print "Properties of the first dimension:"
Debug.Print "Name = " & oFirstDimension.Parameter.Name
Debug.Print "Value = " & oFirstDimension.Parameter.Value
End Sub
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
