Hello
Is it possible to use the translator addin's with apprentice? If so, can someone provide a code snippet how to get the reference to the addin?
Solved by YuhanZhang. Go to Solution.
Apprentice does not support translator addins, it's a light-weight tool. The Apprentice can help to translate some specific formats with using the DataIO. You can refer to the Help document for more details about DataIO if you want.
Mr Brian also post an artical about translating with API, FYI: http://modthemachine.typepad.com/my_weblog/2009/01/translating-files-with-the-api.html
Hello
Thanks, so I can stop searching.
