my problem: I want to place an occurrence onto an other face like using the mate constraint (just without using it:)).
Is there any way to get the transformation matrix to transform the occurrence attached to the face?
When I set the Matrix directly and set the occurrence position via 'occurrence.Transformation' an error occurs.
Can anybody help me?
I were able to solve the problem for myself:
I used Matrix.SetCoordinateSystem to archieve the same result as with the mate feature!
Also calculating the transformation matrix is working now!
