Hello, I am trying to write a snippet of code to do something which I thought would be simple: toggle a hole feature to be either drilled or countersunk based on user input. However, I am getting a very vague "The parameter is incorrect." error when I try to execute this iLogic rule. I'm guessing that I am not using the SetCSink method correctly but I have no idea how to fix the problem. I have checked and all of the variables I am using are already initialized to positive values. Code is posted below, any help would be greatly appreciated!
Dim odoc As PartDocument odoc = ThisApplication.ActiveDocument Dim oHole As HoleFeature oHole = odoc.ComponentDefinition.Features.HoleFeatures.Item(1) Select Case ANCHOR_HOLE_SIZE Case = .25 CSinkDia = .53125 Case = .3125 CSinkDia = .65625 Case = .375 CSinkDia = .78125 Case = .4375 CSinkDia = .84375 Case = .5 CSinkDia = .9375 Case = .625 CSinkDia = 1.1875 Case = .75 CSinkDia = 1.4375 End Select If HOLE_TYPE = "THRU" oHole.SetDrilled() ElseIf HOLE_TYPE = "COUNTERSUNK" oHole.SetCSink(CSinkDia, CSinkAng) End If
Solved by Curtis_Waguespack. Go to Solution.
Hi STVand,
I'm not seeing the error when I (quickly) pasted in your code and ran it, but here is a quick iLogic example that I had on hand that sets a hole feature named Hole1 to a countersink or counterbore based on user input.
After posting and re-reading your question, I realize that I've not addressed the right issue. But I'll try to have a look again tomorrow if I can.
I hope this helps.
Curtis
oInput = InputRadioBox _
("Select one:", "Make Countersink.", "Make Counterbore", True, “iLogic")
oHole = ThisDoc.Document.ComponentDefinition.Features.Item("Hole1")
If oInput = True Then
oHole.SetCSink(1 mm, 82*(PI/180)) '82 degrees
Else
oHole.SetCBore(2 mm, 1 mm)
Curtis, thanks for the reply. I tried making a new part from scratch with just an extrusion and a hole feature named "Hole1" and running your iLogic rule, and I am still getting the same vague "The Parameter is Incorrect" error on running it, regardless of whether I choose countersunk or counterbored. I have read the help docs on the API and the syntax should be correct for the SetCSink/SetCBore methods, so now I am absolutely puzzled.
Solved it! After fooling around a bit with your code, I changed your "mm" to "in" (the native units of the part document) and it worked.
I thought i remember reading that if the object passed into the SetCSink() method didn't have units it would default to the native units, but it seems that isn't true. The correct syntax for it is SetCSink( ### in, ###). Without having in (or mm, or whatever unit) it errors out. Thanks for the help!
