Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
To toggle sketch dimension visibility using iLogic.
10 REPLIES 10
Message 1 of 11
RoyWickrama_RWEI
1864 Views, 10 Replies
Dim oDoc As Inventor.Document
oDoc = ThisDoc.Document
For Each oSketch In oDoc.ComponentDefinition.Sketches
oSketch.Visible = True
Next
I use mostly the above iLogic (several forms of it) when creating sketches. Thanks - it is from one of this user group postings. However, I also would like to have the ability to toggle the sketch dimension visibility too. I request help. Thanks.
10 REPLIES 10
Message 2 of 11
gavbath
in reply to: RoyWickrama_RWEI
I created a part for you, to demonstrate this working.
You were very close. You were looking for Sketch.DimensionsVisible
I used the API help in Inventor to find the relevant boolean for sketch dimension visibility.
Open the attached part, load the iLogic form, and toggle the checkbox to see the result.
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
Message 3 of 11
rhasell
in reply to: gavbath
Hi
Loved the concept, so I decided to use it as well, seeing as though sketch dimensions can sometimes get in the way.
Looking at your part it took me a while to figure out that Dimension visibility is in VBA.
I then Extracted it and placed it directly in iLogic, for future use in my environment.
This works a treat, thank you.
I will put a option in later when I get around to making it live.
Sub Main()
    oDoc = ThisApplication.ActiveDocument
    Dim oSketch As Sketch
        'oSketch.DimensionsVisible = False 'R.H - Test Visible = OFF
	oSketch.DimensionsVisible = True 'R.H - Test Visible = ON
    Next
End Sub
Reg
2024.2
Please Accept as a solution / Kudos
Message 4 of 11
gavbath
in reply to: rhasell
In my example part, the VBA macro was just there for testing, you can delete it and the iLogic form will still work. It's just an iLogic form manipulating a True/False parameter that the iLogic rule uses to control the sketch dimension visibility
Gavin Bath
Message 5 of 11
RoyWickrama_RWEI
Hi Gavin,
Thanks for your reply. I have Inventor 2014 for which I could not open your model. Anyway, based on the 2nd posting (replying you by Rhasell), I got it doing it well for me.
Thanks a lot again.
Roy Wickrama
Message 6 of 11
RoyWickrama_RWEI
Hi Rhasell,
Thank you for the posting. I am getting it through - shown below is my sample run code.
Next
For Each oWorkplane In oDoc.ComponentDefinition.Workplanes
oWorkplane.Visible = False
Next
Best Regards.
Message 7 of 11
gavbath
No problem,
Don't forget that you can use True/False parameters to store the value so you can turn them on and off quickly with an iLogic form.
This was the code I wrote to do the above:
    oSketch.DimensionsVisible = DimensionsVisible '<-- Here, "DimensionsVisible" is a True/False Parameter
Next
Gavin Bath
Message 8 of 11
RoyWickrama_RWEI
Thanks Gavin.
Great. I need this in all my sketches.
I sampled out it with the following.
 oSketch.DimensionsVisible = 0
' oSketch.DimensionsVisible = 1
 Next
Best Regards.
Message 9 of 11
For Each o3DSketch In oDoc.ComponentDefinition.Sketches3d
o3DSketch.Visible = False
o3DSketch.DimensionsVisible = False
Next
Message 10 of 11
rhasell
Gavin
I have finaly made my code live.
Probably a bit messy, but it all works well thanks.
One Question:
I have to press Apply before running the rule  (Done/OK) (External Rule and External Form) Is there some code I can add to the following to bypass this?
'Definitions
'Hide/show Dimensions
	oSketch.DimensionsVisible = Parameter("DIM_S")
Next
'Hide/show Workplanes
oWorkplane.Visible = Parameter("WP_S")
Next
'Hide/show WorkAxes
For Each oWorkaxes In oDoc.ComponentDefinition.Workaxes
oWorkaxes.Visible = Parameter("WA_S")
Next
'Hide/show WorkPoints
For Each oWorkpoints In oDoc.ComponentDefinition.Workpoints
oWorkpoints.Visible = Parameter("WPT_S")
Next
'Hide/show Sketched
oSketch.Visible = Parameter("SKETCH_S")
Next
'Hide/show 3D Geometry
o3DSketch.Visible = Parameter("SKETCH3_S")
o3DSketch.DimensionsVisible = Parameter("SKETCH3_S")
Next
Reg
2024.2
Message 11 of 11
RoyWickrama_RWEI
Sorry, I took so long to accept your post as a solution.
