I am new to Autodesk Inventor, I need to add custom material to apply for the elements. Please guide me..
See overview article on Materials and Appearances and code samples in the Inventor API Help.
The following method could help you:
Assets.Add( AssetType As AssetTypeEnum, LocalType As String, [Name] As Variant, [DisplayName] As Variant ) As Asset
Sub AddNewMaterial() Dim doc As Document Set doc = ThisApplication.ActiveDocument ' Only document appearances can be edited, so that's what's created. ' This assumes a part or assembly document is active. Dim docAssets As Assets Set docAssets = doc.Assets ' Create a new appearance asset. Dim appearance As Asset Set appearance = docAssets.Add( _ AssetTypeEnum.kAssetTypeMaterial, _ "Generic", "MySuperAlloy", "My Super Alloy") End Sub
Thank you Vladimir for your reply, I am trying the same with c# API. However I could not add the Assert AS you done
"Assets.Add( AssetType As AssetTypeEnum, LocalType As String, [Name] As Variant, [DisplayName] As Variant ) As Asset".
Also, Please guide me to get the API for C#.
Thank you.
Try this:
private void btn_AddMaterial_Click(object sender, EventArgs e) { Inventor.PartDocument doc = (PartDocument)oApp.ActiveDocument; // Only document appearances can be edited, so that's what's created. // This assumes a part or assembly document is active. Assets docAssets = doc.Assets; // Create a new appearance asset. Asset appearance = docAssets.Add( AssetTypeEnum.kAssetTypeMaterial, "Generic", "MySuperAlloy", "My Super Alloy"); }
Result:
cheers,
Thank you Vladimir for you valuable support,
I am glad that it has been working, Here for this assert I have to edit Or add my custom "Physical Properties". I have found a working code
Dim oNewMaterial As Inventor.Material
oNewMaterial = oPart.Materials.Add("newmaterial", 1)
' Define the other properties of the material
oNewMaterial.LinearExpansion = 1.19
oNewMaterial.PoissonsRatio = 0.33
' Arbitrarily assigns the first render style in the render styles collection.
oNewMaterial.RenderStyle = oPart.RenderStyles.Item(1)
oNewMaterial.SpecificHeat = 0.23
oNewMaterial.ThermalConductivity = 1.505
oNewMaterial.UltimateTensileStrength = 2.683
oNewMaterial.YieldStrength = 1.813
oNewMaterial.YoungsModulus = 1.6
Is ther any way we can set our own properties for added assert. I need to achieve this c sharp.
Also I am not sure how we got the appreance,color for the assert.
Thank you.
Here is the sample. It creates new material asset and set Poisson ratio value,
then it creates a new appearance asset and change its properties - color and reflectivity.
Inventor.PartDocument doc = (PartDocument)oApp.ActiveDocument; // Only document appearances can be edited, so that's what's created. // This assumes a part or assembly document is active. Assets docAssets = doc.Assets; //------------------------------------------------------- // Create a new material asset MaterialAsset m = (MaterialAsset)docAssets.Add( AssetTypeEnum.kAssetTypeMaterial, "Metal", "MySuperAlloy", "My Super Alloy AAA"); // access some existing material asset MaterialAsset m = (MaterialAsset)doc.Assets["My Super Alloy AAA"]; // get the current Poisson ratio value AssetValue v = m.PhysicalPropertiesAsset["structural_Poisson_ratio"]; Console.WriteLine("Initial value: {0:G}", ((FloatAssetValue)v).Value); //change the Poisson ratio value FloatAssetValue x = (FloatAssetValue)m .PhysicalPropertiesAsset["structural_Poisson_ratio"]; x.Value = 0.13; Console.WriteLine("New value: {0:G}", ((FloatAssetValue)v).Value); //------------------------------------------------------- // Create a new appearance asset. Asset appearance = docAssets.Add( AssetTypeEnum.kAssetTypeAppearance, "Generic", "AAAAA", "AAAAA"); // new color TransientObjects oTransObjects = oApp.TransientObjects; ColorAssetValue color = (ColorAssetValue)appearance["generic_diffuse"]; color.Value = oTransObjects.CreateColor(255, 15, 15); // set reflectivity x = (FloatAssetValue)appearance["generic_reflectivity_at_0deg"]; x.Value = 0.7; x = (FloatAssetValue)appearance["generic_reflectivity_at_90deg"]; x.Value = 0.7; //-------------------------------------------------------
Inventor API Help contains the code sample “Write out all materials to a file” that writes out information about all of the materials in all libraries. This can help to find out physical property names available for a material.
Thanks Vladimir,
With this I can add phusical properties of PossionRatio ..
x.Value = 0.13;
I have tried to add other properties like "Shear Modulus", "YouungModulus" and all other Properties
However I could not achieve this...
I need to add/change a properties of my material.
Can you please help on this..
Thank you
