I have a macro that is called from a loop cycling through all the sheets in a drawing and exporting information from the titleblocks to a property matrix that is then exported to excel. These macros have run jus fine and have not been modified for a few months now. I now have a drawing that's a bit larger than most, 66 sheets. I've ran this macro through it several times before but now it decided that it doesn't like a certain sheet. It fails with an "Automation Error" on the oDoc=ThisApplication.ActiveDocument line on sheet number 61. What could cause that? What does it mean? Did Inventor loose itself? I haven't a clue where to even start looking for the problem.
Solved by mrattray. Go to Solution.
Can you send me the drawing and a minimal version of your program so we can try and reproduce the problem here? You can send it to brian.ekins@autodesk.com.
Brian,
I'd be delighted to have your help on this. I've tried minimalizing the program, but then I can't reproduce the behaviour. I have a suspicion that the problem has to do with a hidden prop set with over 650 props I'm using to transfer data with. I started a pack & go to get an idea of file size and it told me something like 40MB uncompressed. I don't mind sending you that much data if you don't mind recieving it. Otherwise, I'll have to play with it until I can get a minimalized verison that displays the behaviour or find the bug.
Mike
Hi Mike,
I'm ok getting a large data set. I assume it's just Inventor files to exercise the program rather than a lot of code. It's the code that the most important to minimize.
-Brian
Brian,
I just discovered that our attachment limit here is only 10MB. Like I mentioned before, when I slim it down too much I can't reproduce the behaviour. The smallest I can get it to where the error still occurs is 22.5MB packed and zipped. The bulk of the file is just the drawing itself, there isn't a whole lot of code involved. Is there an FTP site or something you can direct me to?
Mike
Well it turns out that reordering the trouble sheet from 61 to 60 somehow fixed the problem. It runs fine now.
