Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Templates Default Location
1 REPLY 1
mirzanasrullah
574 Views, 1 Reply
Inventor Team,
Can you let me know to change the Default Templates Location from the installation directory to the Network Location so that my Mechanical Design Team can use our Assigned Templates.
Waiting for your response,
Thank you.
Nasrullah Baig Mirza,
Mechanical Design Engineer,
1 REPLY 1
YuhanZhang
in reply to: mirzanasrullah
You should be able to change this with either of below two settings:
1. Application default templates:
 Application Options->File->Default templates. This is to set the application default templates, but can be overridden by the Inventor project setting, see below #2.
2. Inventor project templates:
In current active Inventor project, you can set the templates folder from Folder Options->Templates. The Inventor project templates path will override the application default templates path if you change it.
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
