Inventor Team,
Can you let me know to change the Default Templates Location from the installation directory to the Network Location so that my Mechanical Design Team can use our Assigned Templates.
Waiting for your response,
Thank you.
Solved by YuhanZhang. Go to Solution.
You should be able to change this with either of below two settings:
1. Application default templates:
Application Options->File->Default templates. This is to set the application default templates, but can be overridden by the Inventor project setting, see below #2.
2. Inventor project templates:
In current active Inventor project, you can set the templates folder from Folder Options->Templates. The Inventor project templates path will override the application default templates path if you change it.
Hope this helps.
