Telecommute DWF issues.
2 REPLIES 2
Gruff
343 Views, 2 Replies
Hi all,
I am trying to allow some of my Inventor Users to telecommute.
Part of this is the abiility to send a print package to work from home.
I was thinking that DWF might be the best way to go about this.
I see I can drag and drop DWF drawings into a new empty DWF. This is nice  but not very workable when you have hundreds of drawings.
Is there an append method in the ADR API so I can do this programmically?
Thanks.
P.S.  The 2013 ADR activeX will not embed in VB.NET 2010 for some reason.
2 REPLIES 2
Gruff
in reply to: Gruff
Just ran into another issue.  Dragging and Dropping DWF files from explorer into a single new dwf inside ADR causes the Technic Font to turn to some other font that doesn't support the characters set in Technic.
I get Squares for each character.
If I load the original dwf files one at a time the technic font shows up perfectly.
Still hoping someone can shed some light on appending DWF files into one master file from inventor VBA.
I do not see any options to do so....
Gruff
in reply to: Gruff
I found an article that states that DWFx has problems with fonts DWF does not.
I am programmically running the DWF TranslatorAddin with Itembyid(<Guid>) to select the translator.
I copied the sample in Inventor 2011, but i am wondering if it is really the id for the DWFx and not the DWF translator.
as I am getting the font corruption.
