When I run the following code, I get an exception.
Public Sub MySub()
Dim MainFile As System.IO.FileInfo = Nothing
MainFile = GoDoSomething()
End Sub
Public Function GoDoSomething() As System.IO.FileInfo
End Function
The following exception happens when MainFile is initialized:
System.MissingMethodException: Method not found: 'System.Collections.Generic.List`1<System.String> Autodesk.DataManagement.Client.Framework.Vault.Forms.Settings.SelectEntitySettings.get_ActionableEntityClassIds()
I think there is something wrong with my references, but I'm not sure what the last part of the exception is referring to (get_ActionableEntityClassIds()).Everything else can be seen in the object browser. I tried using the 4.0 framework, but the version 20 vault references couldn't find themselves anymore. Any help would be most appreciated.
Mike
Let me update my findings...
I think I've found what is causing the exception, but I'm confused as this was working a few minor changes ago (references were upgraded), and the method in question seems to be allowable (at least what I think the method is).
Public Sub MySub() Dim MainFile As System.IO.FileInfo = Nothing MainFile = GoDoSomething() End Sub Public Function GoDoSomething() As System.IO.FileInfo Dim TestBool As Boolean = False Dim testFile As ACW.File Dim ProjFolder As ACW.Folder = mgrAdmin.DocumentService.GetFolderByPath("$/Projects/") Dim Folder5000 As New VDF.Vault.Currency.Entities.Folder(conn, ProjFolder) Dim EntSettings As VDF.Vault.Forms.Settings.SelectEntitySettings = New VDF.Vault.Forms.Settings.SelectEntitySettings() With EntSettings .ActionableEntityClassIds.Add("FILE") .DialogCaption = "Select Welded Main Assembly Drawing" .MultipleSelect = False .ConfigureActionButtons("Select File", Nothing, Nothing, Nothing) .InitialBrowseLocation = Folder5000 End With End Function
I think there is something wrong with my references, but I'm not sure what the last part of the exception is referring to (get_ActionableEntityClassIds()).Everything else can be seen in the object browser. I tried using the 4.0 framework, but then the version 20 vault references couldn't find themselves anymore. Any help would be most appreciated. I don't understand how anything in the exception relates to the line of code that blows up.
Mike
I got this working hurridley before winter break. I believe the problem was coming from the fact that I had just upgraded Inventor, and hadn't installed the updates for 2015. I could be mistaken, but it was not a code issue. Either that or it came from a duplicate reference that I remember finding using Process Explorer. Sorry I couldn't be more specific.
Mike
