im calling the Inventor-API via COM in C#. Frist I'm creating the Object, then setting the Visible-Property to true. After that im releasing the object (I'm not calling the Quit-Method). If the user then closes the Inventor Window, the process will stuck in the Taskmanager, and also wont be able to be interopted anymore.
[CODE]
Inventor.Application app = Activator.CreateInstance(Type.GetTypeFromProgID("Inventor.Application")) as Inventor.Application;
app.Visible = true;
Marshal.FinalReleaseComObject(app);
app = null;
[/CODE]
How can i tell Inventor, to really close completly after the User closes the Window?
Greetings
Felix
Hi Felix,
It’s as expected. Starts Inventor through CreateIntance, Inventor is embedded run (i.e. the main(parent) process calls Inventor as a sub(child) process). So main process should explicitly quit Inventor (Application.Quit). It is suggested that you terminate the sub process when your application closes. e.g.
Private oApp As Inventor.Application
Private Sub Form_Load()
Set oApp = CreateObject("Inventor.Application")
MsgBox "Inventor was created!"
End Sub
Private Sub Form_Terminate()
If oApp Is Nothing Then
MsgBox "Inventor was quit!"
Else
oApp.Quit ‘ terminate the Inventor process
Set oApp = Nothing
End Sub
Xiaodong Liang
Developer Technical Services
So there is no way, that i can open Autodesk, create any file, and keep it open so the user can edit it?
Do i always have to create a new Instance, Create the File, Close the Instance, and start a new Instance via ShellExecute?
Other Applications, like Microsoft Word, doesnt have this behavior.
I am having the same problem. Want to start Inventor, create or open a specific file and let the user edit it. However, we end with zombie inventor processes that have to be ended in the Task manager.
We are using AI 2010. Has this been fixed in 11 or 12?
Best regards
Jeppe
Is there a workaround available for this issue? Using Inventor 2013, and stuck up with background Inventor processes that fail to close when i had started inventor via COM.
So currently i start an "embedded" instance via CreateInstance.
I leave that Instance in background for later usage, due to high startup times.
If that instance is running and i open up a file via the explorer, it wont start another instance. Instead it will popup my hidden "embedded" instance, which is set to SilentOperation and have different other settings too, and keeps using this. How can i disable the "reusage" of my "embedded" instance?
Regards
Felix
Try something like the below as this will always try to get a running instance before creating a new one.
Try 'this will connect to a current running instance of inventor oApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application") Catch ex As Exception 'if the instance was not started to connect to then we will create a new instance oApp = CreateObject("Inventor.Application") End Try
I have written a small example of the problem.
[Code]
static void Main(string[] args)
Console.WriteLine("COM-Instance-Problem");
Type tInventor = Type.GetTypeFromProgID("Inventor.Application");
Inventor.Application oInventor = (Inventor.Application)Activator.CreateInstance(tInventor);
Inventor.Document oInventorDocument = oInventor.Documents.Add(Inventor.DocumentTypeEnum.kPartDocumentObject, string.Empty, true);
Console.WriteLine("At this point, im doing some actions, i emulate them with this ReadLine");
Console.ReadLine();
oInventorDocument.Close(true);
oInventor.Quit();
[/Code]
So when you now would start this up with no Inventor running, it will create an instance of it. While the program stops at the ReadLine(), you can open up a file in the explorer. That opening will REUSE the active Inventor-Process! (I tested this with microsoft word, which will start a new process).
First thing is, the process seems to be some kind of bugged (Im using Inventor 2014), as it wont display the Ribbon correctly.
But more critical is, that when my operation is finished (Go back to the Program and push Enter), it will completely kill the Inventor, and also the opened File which you might be working on.
My question now is: How do i handle this? Is it supposed to "reuse" my "embedded" inventor process?
Regards
Felix
