Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Skip rule
4 REPLIES 4
GosponZ
441 Views, 4 Replies
Skip rule
I'm running one rule with few rules inside but i need one rule in certain situation to skip. It would be the best to be as boolean param. yes to run that rule and no to skip and to go on next rule until is done.
Can you guys help
Thank you
4 REPLIES 4
Vladimir.Ananyev
in reply to: GosponZ
If you  add boolean user parameter e.g. NeedRule to your model, then the following rule could call the dependent rule "ruleName" only if NeedRule = True
If NeedRule Then
  iLogicVb.RunRule("ruleName")
End If
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
GosponZ
in reply to: Vladimir.Ananyev
I fixed now is working
Thank you
Vladimir.Ananyev
Great!
Vladimir Ananyev
GosponZ
This rule came from Vladimir Ananyjev
It is working very well. Thank you
MsgBox("Start of Main Rule") 'Run rule 1 iLogicVb.RunRule("Rule1") 'Run rule 2 iLogicVb.RunRule("Rule2") R = MessageBox.Show("Do you want to run Rule3 ?", _ "Ask user for decision", _ MessageBoxButtons.YesNo, _ MessageBoxIcon.Question) If R = vbYes Then 'Run rule 3 iLogicVb.RunRule("Rule3") Else MsgBox("Skip Rule3") End If
