Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
SketchLine Gemoetry Wrong Results
3 REPLIES 3
mario.lung
328 Views, 3 Replies
i draw a Sketch Line and debug the Start and EndPoint Coordinates
    Dim oStartPoint
    Dim oEndPoint
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches(1)
    Dim oSketchLine As SketchLine
    For Each oSketchLine In oSketch.SketchLines
        Dim dCoordinates(2) As Double
        Call oSketchLine.Geometry.StartPoint.GetPointData(dCoordinates)
        Debug.Print "StartPoint = " & dCoordinates(0) & ", " & dCoordinates(1)
        Call oSketchLine.Geometry.EndPoint.GetPointData(dCoordinates)
        Debug.Print "EndPoint = " & dCoordinates(0) & ", " & dCoordinates(1)
       Debug.Print "---"
    Next
 The Results is
StartPoint = 1.11022302462516E-16, 4.49956402428943
EndPoint = 2.00100803964792, 4.49956402428943
when i look in the Drawing is the Result
so my Problem is when i draw a Line with the Coordinates there i get its the Line Diffrent to the Original Line!
ths for Hints Tips or Solutions
Mario
3 REPLIES 3
Jon.Dean
in reply to: mario.lung
I have asked one of the ADN experts to comment on this.
Jon
Jon Dean
ekinsb
The picture is too small to be able to see what's going on.  How are you drawing the second line; using the API or interactively?  The coordinates returned when you query the start and end points are 2D coordinates in sketch space and in centimeters.  Depending on how you're drawing the second line it might be in different units, in model space, or in the space of a different sketch.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
mario.lung
in reply to: ekinsb
Hey,
I have now the Result
when i dosent editclose or update the Document
the Result is wrong
after this the resoults are rigth!
thx for Help
Mario
