Inventor Customization
Distinguished Contributor
naresh_kalyan
Message 1 of 6 (268 Views)
simpleAddin
268 Views, 5 Replies
04-01-2013 11:42 PM
Greetings..
Hi everyone,
 I would like to create an addin in VS2010 & IN2012. How I could able to do this?
I have gone through the help and started with "simpleAddin". But, while building I could able to see the following error.
The same error for all Addins. Someone's help would be greatly appreciated.
Thanks in advance.
Error    1    The command "mt.exe -manifest "E:\Program Files\Autodesk\Inventor 2012\SDK\DeveloperTools\Samples\VB.NET\AddIns\SimpleAddIn\My Project\SimpleAddIn.manifest" -outputresource:"E:\Program Files\Autodesk\Inventor 2012\SDK\DeveloperTools\Samples\VB.NET\AddIns\SimpleAddIn\bin\SimpleAddIn.dll";#2
" exited with code 9009.    SimpleAddIn
ADN Support Specialist
xiaodong.liang
Message 2 of 6 (234 Views)
Re: simpleAddin
04-12-2013 11:22 PM in reply to: naresh_kalyan
Firstly, please take a look at the tutorial on registry-free addin
http://modthemachine.typepad.com/my_weblog/2012/02/migrate-net-add-ins-to-registry-free.html
As to the error you hit, it is just an error in the post-build script. in this case, that would mean the 'mt.exe' does not exist in the system path. you will need to search where the 'mt.exe' is on your machine and add the path to the system path. Of course, you can also use absolute path ,e.g.
"c:\...\mt.exe"   "....addin.manifest"  "....\addin.dll"
Xiaodong Liang
Developer Technical Services
Autodesk Developer Network
naresh_kalyan
Message 3 of 6 (222 Views)
Re: simpleAddin
04-16-2013 06:38 AM in reply to: naresh_kalyan
Thank you for your reply. I have gone through entire help. But, still I could not able to create a Valid .manifest file.
I could write the code and build successfully (Prior to this I used to work with Macros)
Could you please elaborate towards .manifest file
Thanks for your time.
naresh_kalyan
Message 4 of 6 (211 Views)
Re: simpleAddin
04-18-2013 04:10 AM in reply to: naresh_kalyan
Hi Everyone...
I have followed the steps as mentioned below. But, still in vain.
created a Project by taking Autodesk Inventor Addin Template
created a solution
Created a "Testaddin.manifest" file in /Myproject/ folder
Added "Testaddin.manifest" into the solution
Created "Testaddin.addin" file in C:\Documents and Settings\All Users\Application Data\Autodesk\Inventor 2012\Addins
Build the solution
-Build Succeeded-
Copied the Testaddin.dll from "\TestAddin\bin" to "\Inventor 2012\Bin"
Still I could not able to see "TestAdin" in Autodesk Inventor - Addins.
It seems that I'm almost nearer in creating Addin.
Anyone's help would be greatly appreciated.
Regards
NKalyan
xiaodong.liang
Message 5 of 6 (192 Views)
Re: simpleAddin
04-26-2013 12:14 AM in reply to: naresh_kalyan
Hi naresh_kalyan,
this is a blog on the registry-free addin. You will know what is manifest file.
http://modthemachine.typepad.com/my_weblog/add-in-creation/
Xiaodong Liang
xiaodong.liang
Message 6 of 6 (191 Views)
Re: simpleAddin
04-26-2013 12:16 AM in reply to: naresh_kalyan
you seemed to forget to put the *.addin file to the specific folders which Inventor will look for the addins are to be loaded.
again, please take a look at the blog I mentioned above and followed the steps.
Xiaodong Liang
