I have a very simple iLogic code that I am running before save on my drawing template. It loads the correct border size based on the sheet size. The problem is, all my borders are zone borders but when it applies the new border, it erases all numbers and letters marking the zones. They don't get erased if I change the title block manually. Anyone know why it does that?
If ActiveSheet.Size = "A" ActiveSheet.Border = "The Name of my A title block" End If
Solved by adam.nagy. Go to Solution.
@adam.nagy wrote:(...)
The real solution for you would be if AddBorder() functioned as it should, but not not sure when that will happen.
this is also my case, I need it working fine in VBA, otherwise I have to start building the workaround of many size-dependand borders, which is awful.
Any chance to get it working in reasonable time? It's 4 years already...
Hi Massimo,
The issue has been fixed for Inventor 2017
I just checked it there and AddBorder() for a Zone Border seems to work fine now.
Cheers,
...well, this is very good news.
I have a few 2017 available by another company, I'll take a look at it and report accordingly.
Thanks!!
