Can anybody answer the following question???
I need to "Programatically", using Visual Studio, set the default printers paper size to either "A4" or "A3".
I have the following code that gets the required paper size ("A4" or "A3") from the registry and checks that the default printer supports "A3". If it does I want to set the paper size to "A3".
Can this be done????
Here is my code so far....
Imports Microsoft.Win32
Public Class Form1
Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Dim SetPaperSize As String
Dim PrinterPaperSize As String
SetPaperSize = My.Computer.Registry.GetValue("HKEY_CURRENT_USER\Software\MechTools\", "Printer Paper Size", "0")
For Counter = 0 To PrintDialog1.PrinterSettings.PaperSizes.Count
PrinterPaperSize = PrintDialog1.PrinterSettings.PaperSizes.Item(Counter).PaperName
If PrinterPaperSize = SetPaperSize Then
' MsgBox(SetPaperSize) HERE IS WHERE I NEED THE CODE TO SET THE PAPER SIZE
Exit For
Next
End
End Sub
End Class
Many thanks in advance!!!
Frankly, I did not understand what is your problem. I just copied the API sample here, where you can see how to set the paper size. Hope it helps.
Public Sub PrintDrawing() ' Set a reference to the print manager object of the active document. ' This will fail if a drawing document is not active. Dim oPrintMgr As DrawingPrintManager Set oPrintMgr = ThisApplication.ActiveDocument.PrintManager ' Get the name of the printer that will be used. If MsgBox("Using printer """ & oPrintMgr.Printer & """ Do you want to continue?", vbYesNo + vbQuestion) = vbNo Then ' Change to another printer. Dim sPrinterName As String sPrinterName = InputBox("Enter name of new printer:", "New Printer") If sPrinterName = "" Then Exit Sub Else oPrintMgr.Printer = sPrinterName End If End If ' Set to print in color. oPrintMgr.ColorMode = kPrintColorPalette ' Set to print two copies. oPrintMgr.NumberOfCopies = 2 ' Set to print using portrait orientation. oPrintMgr.Orientation = kPortraitOrientation ' Set the paper size. oPrintMgr.PaperSize = kPaperSize11x17 ' Set to print all sheets. oPrintMgr.PrintRange = kPrintAllSheets ' Set to print full scale. oPrintMgr.ScaleMode = kPrintFullScale ' Submit the print. oPrintMgr.SubmitPrint ' Change the number of copies to 1. oPrintMgr.NumberOfCopies = 1 ' Change the paper size to a custom size. The units are in centimeters. oPrintMgr.PaperSize = kPaperSizeCustom oPrintMgr.PaperHeight = 15 oPrintMgr.PaperWidth = 10 ' Get and set the current sheet range. Dim iFromSheet As Long Dim iToSheet As Long Call oPrintMgr.GetSheetRange(iFromSheet, iToSheet) MsgBox "Current sheet range is " & iFromSheet & " to " & iToSheet & Chr(13) & _ "Setting to print sheets 1-2." ' Change the print range to print sheets 1 through 2. oPrintMgr.PrintRange = kPrintSheetRange Call oPrintMgr.SetSheetRange(1, 2) ' Submit the print. oPrintMgr.SubmitPrint End Sub
