Can someone tell me an code to make in VBA editor, that read my part list (code, quantity and designition), and appears like this:
Example: Part list contains 5 codes.
Read active idw.
Read code nº1 (msg with code+quantity+designition)
Read code nº2 (msg with code+quantity+designition)
Read code nº3 (msg with code+quantity+designition)
Read code nº4 (msg with code+quantity+designition)
Read code nº5 (msg with code+quantity+designition)
msg ("Finish")
Solved by Fredalone. Go to Solution.
Help?
Its just MsgBox... dont need to connect to SQL database yet... I just want to know how I find each part of the list, 1 by 1... and in each one, appears an message saying the quantity, item number, designation or/and code .
Please, help 😞
This method shows going through each row and getting the column with the heading caption. It is only going to work with the first parts list on the active sheet.
Dim oDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument Dim oSheet As Sheet = oDrawDoc.ActiveSheet Dim oPartsList As PartsList = oSheet.PartsLists.Item(1) For Each oRow As PartsListRow In oPartsList.PartsListRows Dim RowArray(oPartsList.PartsListColumns.Count - 1) As String For I As Integer = 1 To oPartsList.PartsListColumns.Count RowArray(I - 1) = oPartsList.PartsListColumns.Item(I).Title & vbTab & oRow.Item(I).Value Next MsgBox(String.Join(vbLf, RowArray)) Next
It works fine in Inv 2012, how are you trying to use it? What programming environment are you working in?
Dear,
Can help me, how to filtering a part list use view by assembly drawing, with VBA editor or iLOGic code.
there is no class system for filter in partlist class.
im use autodesk inventor 2010, and get install use ilogic add-ons 2010
i want to get automation system for my inventor design.
Thx.
Ihsan Surahman,
Hi d_great_ice,
See this link:
I hope this helps.
Curtis
