Hello All,
Please look at the image (also Attached)
I want to fetch either,
<> The name of the item selected OR
<> The componentOccurrence.Name of the referenced Assembly OR
<> (the best) The DrawingCurve(s) selected in the Window
Keep in mind that the idea is it to allow the user to make more than one selection (i.e. multiple components in browser window)
I have an alternative to make the user to manually select the drawingCurves in the Window, but that is not an elegnt solution to hat I am trying to achive.
If anyone can give me a heads up on what is the object type of the item I am selecting (I tried ComponentOccurrence but failed), even that would be very helpful.
Thanking you all,
Wajih
Solved by adam.nagy. Go to Solution.
Hi Wajih,
If I understand you correctly then the following VBA code should be of help:
Function GetSelectedItems(nodes As BrowserNodesEnumerator) As String Dim node As BrowserNode For Each node In nodes If node.Selected Then GetSelectedItems = GetSelectedItems + vbCrLf + node.BrowserNodeDefinition.Label End If GetSelectedItems = GetSelectedItems + GetSelectedItems(node.BrowserNodes) Next End Function Sub GetSelectedItemsInBrowser() Dim bp As BrowserPane Set bp = ThisApplication.ActiveDocument.BrowserPanes("DlHierarchy") Dim items As String items = GetSelectedItems(bp.TopNode.BrowserNodes) MsgBox items End Sub
Cheers,
