Inventor Customization
Valued Contributor
simonsson
Message 1 of 5 (1,413 Views)
SaveAs Stp
1413 Views, 4 Replies
09-30-2010 06:29 AM
I'm trying to start up Inventor, open an assembly and save it to stp using API (C#).
This works perfectly fine with parts, but not with assemblies.
doc.SaveAs("fil.stp", true); // doc is an iam-file (Inventor.Document)
...gives me error: "Invalid parameter... HRESULT: 0x80070057 (E_INVALIDARG))".
I start up Inventor visually so I know that the assembly opens up correctly with all parts and subassemblies.
If I do it manually it works fine with Export -> CAD Format -> STEP (stp).
Does anyone have any ideas why or what I'm doing wrong?
Thanks!
I found the problem. Inventor was not ready loading when I opened the assembly. Thanks!
Board Manager
sanjay.ramaswamy
Message 2 of 5 (1,409 Views)
Re: SaveAs Stp
09-30-2010 11:57 AM in reply to: simonsson
Can you try providing that full path for the output file, rather than just "fil.stp"? I tried the following VBA macro on the active assembly document in Inventor 2011 and it works for me.
Sub SaveAsSTP()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    Call oDoc.SaveAs("C:\temp\test.stp", True)
End Sub
Valued Contributor
simonsson
Message 3 of 5 (1,397 Views)
Re: SaveAs Stp
10-01-2010 02:46 AM in reply to: sanjay.ramaswamy
New Member
Belero
Message 4 of 5 (1,102 Views)
Re: SavAs Step
03-28-2011 01:42 AM in reply to: simonsson
Would it be possible to add options for the step export within the code?
Specifically, does the export step have savecopyas options that can be set just like in the dxf/pdf translator addin?
Goal: I want to preset the export options for the step file.
options I would like to "grab" & "set":
- Application Protocol: 203 or 214, then 214 alone, 214 IS or 214 DIS.
- Include Sketches (True/False I guess)
regards
Valued Mentor
Ktelang
Message 5 of 5 (699 Views)
Re: SaveAs Stp
11-14-2012 07:46 AM in reply to: sanjay.ramaswamy
How can I access the saving options.
I want to exclude the sketches while saving as stp
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
