Inventor Customization
Valued Mentor
6 Kudos
Post 1 of 3
Saveas STP -save options
211 Views, 2 Replies
11-14-2012 12:00 PM
How can I access the save option while saving stp
Call oDoc.SaveAs("C:\temp\test.stp", True)
using this I get the default "include sketches" options
I want to exclude sketches using API
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
When using the SaveAs method you get the default behavior and don't have control over the various translator settings.  In order to control the setting you need to drive the translator directly.  There are several samples in the API help that demonstrate this and there's on in particular that shows how to write out a STEP file.  The sample doesn't show all of the options that are available.  That's also listed in the API help but when I just looked for it now found it's not accessible through the index.  Instead you have to search for it.  We need to correct this.  In the meantime, I copied and pasted the material in a Word document, which I've attached.  You'll see the option for excluding sketches there.
ADN Support Specialist
58 Kudos
Post 2 of 3
Re: Saveas STP -save options
11-14-2012 12:44 PM in reply to: Ktelang
Brian Ekins
Developer Technical Services
Autodesk Developer Network
Valued Mentor
6 Kudos
Post 3 of 3
11-14-2012 01:58 PM in reply to: ekinsb
Thanks Brian,
oOptions.Value("IncludeSketches") = False
This did the trick
