Using Inventor 2015, I have a some code I have been using to iterate through factories to build prints. Now I am now trying to do the same thing with assemblies with multiple sheets. Everything works great until I get to: oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".pdf", True).
This function appears to only create a pdf of the active sheet. I need all sheets exported to the same pdf. I have included a section of the code I am using.
'iterate through the rows Dim oRow As iAssemblyTableRow 'iPartTableRow For Each oRow In oFactory.TableRows 'make this the active row so the model will recompute. oFactory.DefaultRow = oRow 'get the name of the ipart oMemberFile = oRow.MemberName oMemberName = oRow.MemberName oMemberTemplate = oRow.Item(iTemplateColumnIndex).Value 'oParentPartDoc.ComponentDefinition.Parameters.Item("template").Value ' select parametr by name oMemberScale = oRow.Item(iScaleColumnIndex).Value If Len(Dir(templatesfileLocation & oMemberTemplate & ".idw")) > 0 Then 'get the drawing template Set oDrawingDoc = ThisApplication.Documents.Open(templatesfileLocation & oMemberTemplate & ".idw") Set oSheets = oDrawingDoc.Sheets For Each oSheet In oSheets 'get the drawing view Dim oView As DrawingView For Each oView In oSheet.DrawingViews Select Case oView.Name Case "FRONT", "BACK", "ISO" Call oView.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(ipartsfileLocation & oMemberFile & ".iam") oView.[Scale] = oMemberScale oView.IsRasterView = False Case Else End Select Next Dim oPartsList As PartsList For Each oPartsList In oSheet.PartsLists oPartsList.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference (ipartsfileLocation & oMemberFile & ".iam") Next Next oSheet Call oDrawingDoc.Update2(True) 'save copy as one new idw using the member name in the prints folder Call oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".idw", True) Call oDrawingDoc.MakeAllViewsPrecise Call oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".pdf", True) Call oDrawingDoc.Close
Solved by rossano_praderi. Go to Solution.
Hi insomnix,
this is my sample code which can be suitable for your needs.
Sub Main printsfileLocation=ThisDoc.Path oMemberName=ThisDoc.FileName(False) 'without extension exportPDF(printsfileLocation, oMemberName, ThisApplication.activedocument) End Sub Sub exportPDF(oPath As String, oFileName As String, oDocument As Document) Try oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium Dim oDrawing as DrawingDocument = oDocument Dim sheetCount As Integer = oDrawing.Sheets.Count If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange oOptions.Value("Custom_Begin_Sheet") = 1 oOptions.Value("Custom_End_Sheet") = sheetcount End If oDataMedium.FileName = oPath & "\" & oFileName & ".pdf" ' check carefully this line oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Catch End Try End Sub
Bregs
Rossano Praderi
I found something similar to this late yesterday after I posted my problem: http://modthemachine.typepad.com/my_weblog/2009/01/
This was an old post from 2009, so I didn't know if it was still a good solution in inventor 2015. Thanks for confirming that 6 years old code is still the best solution to export multiple sheets to a single pdf.
Hi. I have a funny problem with this code. Not all the drawings save a pdf. there is no error massage but some drawings with this code just does not make a pdf. I have checked the event is triggering but no pdf is made in the same folder.
here is the code that I am using
InventorVb.DocumentUpdate()
'------------------- Complex code added to save all sheets ----------------
'oDocument = ThisApplication.ActiveDocument
oDocument = ThisDoc.Document
'oOptions.Value("Remove_Line_Weights") = 1
'this publish all doens't work
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'try a different publish all command
oOptions.Value("Publish_All_Sheets") = 1
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'Set the PDF target file name
oDataMedium.FileName = ThisDoc.FileName & ".pdf"
'Publish document
I havce made one change to the code.
The reason is to get save all to work. That way I can open the all the drawings and hit the save all button and get new pdfs with multipe sheets.
Just need to point out that this is no when I get the probem. I get the problem when i save a drawing regardless if i use save or save all.
I have checed the following.
1. That the rual is triggered. I used a messaged box at the end and it is
2. That the code is the same between drawing which works and which does not.
Any ideas?
Here is the idw with the part that is giving the problems.
Help please. i have over 300 drawings i need to convert to PDF's and some works and others don't
I've checked your code, I've found only a problem with the assignation of path and filename.
Attached you can find your file with two ilogic rules, both of them completely tested and fully working.
Bregs
Rossano Praderi
