Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Saveas all IDW sheets to PDF
6 REPLIES 6
insomnix
929 Views, 6 Replies
Using Inventor 2015, I have a some code I have been using to iterate through factories to build prints. Now I am now trying to do the same thing with assemblies with multiple sheets. Everything works great until I get to: oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".pdf", True).
This function appears to only create a pdf of the active sheet. I need all sheets exported to the same pdf. I have included a section of the code I am using.
    'iterate through the rows
    Dim oRow As iAssemblyTableRow 'iPartTableRow
    For Each oRow In oFactory.TableRows
        'make this the active row so the model will recompute.
        oFactory.DefaultRow = oRow
        'get the name of the ipart
        oMemberFile = oRow.MemberName
        oMemberName = oRow.MemberName
        oMemberTemplate = oRow.Item(iTemplateColumnIndex).Value 'oParentPartDoc.ComponentDefinition.Parameters.Item("template").Value ' select parametr by name
        oMemberScale = oRow.Item(iScaleColumnIndex).Value
        If Len(Dir(templatesfileLocation & oMemberTemplate & ".idw")) > 0 Then
            'get the drawing template
            Set oDrawingDoc = ThisApplication.Documents.Open(templatesfileLocation & oMemberTemplate & ".idw")
            Set oSheets = oDrawingDoc.Sheets
            For Each oSheet In oSheets
                'get the drawing view
                Dim oView As DrawingView
                For Each oView In oSheet.DrawingViews
                    Select Case oView.Name
                        Case "FRONT", "BACK", "ISO"
                            Call oView.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference(ipartsfileLocation & oMemberFile & ".iam")
                            oView.[Scale] = oMemberScale
                            oView.IsRasterView = False
                        Case Else
                    End Select
                Next
                Dim oPartsList As PartsList
                For Each oPartsList In oSheet.PartsLists
                    oPartsList.ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference (ipartsfileLocation & oMemberFile & ".iam")
                Next
            Next oSheet
            Call oDrawingDoc.Update2(True)
            'save copy as one new idw using the member name in the prints folder
            Call oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".idw", True)
            Call oDrawingDoc.MakeAllViewsPrecise
            Call oDrawingDoc.SaveAs(printsfileLocation & oMemberName & ".pdf", True)
            Call oDrawingDoc.Close
6 REPLIES 6
rossano_praderi
in reply to: insomnix
Hi insomnix,
this is my sample code which can be suitable for your needs.
Sub Main
	printsfileLocation=ThisDoc.Path
	oMemberName=ThisDoc.FileName(False) 'without extension
	exportPDF(printsfileLocation, oMemberName, ThisApplication.activedocument)
End Sub
Sub exportPDF(oPath As String, oFileName As String, oDocument As Document)
	Try
		oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
		("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
		oContext = ThisApplication.TransientObjects.CreateTranslationContext
		oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
		oOptions = ThisApplication.TransientObjects.CreateNameValueMap
		oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
		Dim oDrawing as DrawingDocument = oDocument
		Dim sheetCount As Integer = oDrawing.Sheets.Count
		If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
			oOptions.Value("All_Color_AS_Black") = 1
			oOptions.Value("Remove_Line_Weights") = 1
			oOptions.Value("Vector_Resolution") = 400
			oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
			oOptions.Value("Custom_Begin_Sheet") = 1
			oOptions.Value("Custom_End_Sheet") = sheetcount
		End If
		oDataMedium.FileName = oPath & "\" & oFileName & ".pdf" ' check carefully this line
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
	Catch
	End Try
End Sub
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Tags (1)
insomnix
I found something similar to this late yesterday after I posted my problem: http://modthemachine.typepad.com/my_weblog/2009/01/
This was an old post from 2009, so I didn't know if it was still a good solution in inventor 2015. Thanks for confirming that 6 years old code is still the best solution to export multiple sheets to a single pdf.
rossano_praderi
Your are welcome.
in reply to: rossano_praderi
Hi. I have a funny problem with this code. Not all the drawings save a pdf. there is no error massage but some drawings with this code just does not make a pdf. I have checked the event is triggering but no pdf is made in the same folder.
here is the code that I am using
InventorVb.DocumentUpdate()
'------------------- Complex code added to save all sheets ----------------
'oDocument = ThisApplication.ActiveDocument
oDocument = ThisDoc.Document
'oOptions.Value("Remove_Line_Weights") = 1
'this publish all doens't work
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'try a different publish all command
oOptions.Value("Publish_All_Sheets") = 1
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
'Set the PDF target file name
oDataMedium.FileName = ThisDoc.FileName & ".pdf"
'Publish document
I havce made one change to the code.
The reason is to get save all to work. That way I can open the all the drawings and hit the save all button and get new pdfs with multipe sheets.
Just need to point out that this is no when I get the probem. I get the problem when i save a drawing regardless if i use save or save all.
I have checed the following.
1. That the rual is triggered. I used a messaged box at the end and it is
2. That the code is the same between drawing which works and which does not.
Any ideas?
Here is the idw with the part that is giving the problems.
Help please. i have over 300 drawings i need to convert to PDF's and some works and others don't
rossano_praderi
I've checked your code, I've found only a problem with the assignation of path and filename.
Attached you can find your file with two ilogic rules, both of them completely tested and fully working.
Bregs
Rossano Praderi
