Save flat pattern as dxf with iLogic rule - Inventor 2012
5 REPLIES 5
3626 Views, 5 Replies
Hello. I have read all the topics about rule that save flat pattern (.ipt) as .dxf file. Unfortunately, It doesn't work with Inventor 2012. I found rule by Rob Cohee and it works but it saves all lines. I need dxf file with only outer and inner profile, no bend lines.
Do you know any rule that I mean? Help would be very appreciated.
Thanks in advance.
5 REPLIES 5
Raider_71
Lance127
add the layers you don't want to the Invisiable layer switch in the sout = line in Robs rule. It will look sort of like this
sOut = "FLAT PATTERN DWG?AcadVersion=2000&OuterProfileLayer=Burn&InteriorProfilesLayer=Burn&InvisibleLayers=IV_UNCONSUMEND_SKETCHES;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_ARC_CENTERS;IV_TOOL_CENTER_DOWN;IV_TOOL_CENTER;IV_ARC_CENTERS;IV_TANGENT;IV_BEND;IV_BEND_DOWN&SplineTolerance Double 0.01"
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
white127
Good solution! I don't belive that it works! Thank you very much.
in reply to: Lance127
Could you add color of bend line and insert a comment about <partnumber> <thinkness> <material> inside dxf file?
Raider_71
The latest DXF Exporter can do all that and some more.
http://www.mgfx.co.za/tools-for-inventor.htm
Cheers
