The Sample code from the 2013 Inventor help for Creating sketched symbol definitions doesn't want to work.
Friend ThisApplication As Inventor.Application
PublicSub CreateSketchedSymbolDefinition()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc AsDrawingDocument = ThisApplication.ActiveDocument
' Create the new sketched symbol definition.
Dim oSketchedSymbolDef AsSketchedSymbolDefinition
oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Add(
"Circular Callout")
' Open the sketched symbol definition's sketch for edit. This is done by calling the Edit
' method of the SketchedSymbolDefinition to obtain a DrawingSketch. This actually creates
' a copy of the sketched symbol definition's and opens it for edit.
Dim oSketch AsDrawingSketch
Call oSketchedSymbolDef.Edit(oSketch)
Dim oTG AsTransientGeometry
oTG = ThisApplication.TransientGeometry
' Use the functionality of the sketch to add sketched symbol graphics.
Dim oSketchLine AsSketchLine
oSketchLine = oSketch.SketchLines.AddByTwoPoints(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(20, 0))
Dim oSketchCircle AsSketchCircle
oSketchCircle = oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(22, 0), 2)
Call oSketch.GeometricConstraints.AddCoincident(oSketchLine.EndSketchPoint, oSketchCircle)
' Make the starting point of the sketch line the insertion point
oSketchLine.StartSketchPoint.InsertionPoint =
True
' Add a prompted text field at the center of the sketch circle.
Dim sText AsString
sText =
"\</Prompt\>Enter text 1\</Prompt\>"
Dim oTextBox AsTextBox
oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(22, 0), sText)
oTextBox.VerticalJustification =
VerticalTextAlignmentEnum.kAlignTextMiddle
oTextBox.HorizontalJustification =
HorizontalTextAlignmentEnum.kAlignTextCenter
Call oSketchedSymbolDef.ExitEdit(True)
EndSub
PublicSub InsertSketchedSymbolOnSheet()
oDrawDoc = ThisApplication.ActiveDocument
' Obtain a reference to the desired sketched symbol definition.
oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item(
"Circular Callout")
Dim oSheet AsSheet
oSheet = oDrawDoc.ActiveSheet
' This sketched symbol definition contains one prompted string input. An array
' must be input that contains the strings for the prompted strings.
Dim sPromptStrings(0) AsString
sPromptStrings(0) =
"A"
' Add an instance of the sketched symbol definition to the sheet.
' Rotate the instance by 45 degrees and scale by .75 when adding.
' The symbol will be inserted at (0,0) on the sheet. Since the
' start point of the line was marked as the insertion point, the
' start point should end up at (0,0).
Dim oSketchedSymbol AsSketchedSymbol
oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oTG.CreatePoint2d(0, 0), (3.14159 / 4), 0.75, sPromptStrings)
EndSub
Solved by Vladimir.Ananyev. Go to Solution.
This code works fine for me. Pay attention to prompted text format.
Public Sub CreateSketchedSymbolDefinition() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument ' Create the new sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition _ = oDrawDoc.SketchedSymbolDefinitions.Add("Circular Callout") ' Open the sketched symbol definition's sketch for edit. This is done by calling the Edit ' method of the SketchedSymbolDefinition to obtain a DrawingSketch. This actually creates ' a copy of the sketched symbol definition's and opens it for edit. Dim oSketch As DrawingSketch = Nothing Call oSketchedSymbolDef.Edit(oSketch) Dim oTG As TransientGeometry = ThisApplication.TransientGeometry ' Use the functionality of the sketch to add sketched symbol graphics. Dim oSketchLine As SketchLine = oSketch.SketchLines _ .AddByTwoPoints(oTG.CreatePoint2d(0, 0), oTG.CreatePoint2d(20, 0)) Dim oSketchCircle As SketchCircle = oSketch.SketchCircles _ .AddByCenterRadius(oTG.CreatePoint2d(22, 0), 2) Call oSketch.GeometricConstraints.AddCoincident( _ oSketchLine.EndSketchPoint, oSketchCircle) ' Make the starting point of the sketch line the insertion point oSketchLine.StartSketchPoint.InsertionPoint = True ' Add a prompted text field at the center of the sketch circle. Dim sText As String = "<Prompt>Enter text 1</Prompt>" Dim oTextBox As Inventor.TextBox oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(22, 0), sText) oTextBox.VerticalJustification = VerticalTextAlignmentEnum.kAlignTextMiddle oTextBox.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter Call oSketchedSymbolDef.ExitEdit(True) End Sub Public Sub InsertSketchedSymbolOnSheet() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument ' Obtain a reference to the desired sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition _ = oDrawDoc.SketchedSymbolDefinitions.Item("Circular Callout") Dim oSheet As Sheet = oDrawDoc.ActiveSheet ' This sketched symbol definition contains one prompted string input. An array ' must be input that contains the strings for the prompted strings. Dim sPromptStrings(0) As String sPromptStrings(0) = "AAAAA" Dim oTG As TransientGeometry = ThisApplication.TransientGeometry ' Add an instance of the sketched symbol definition to the sheet. ' Rotate the instance by 45 degrees and scale by .75 when adding. ' The symbol will be inserted at (0,0) on the sheet. Since the ' start point of the line was marked as the insertion point, the ' start point should end up at (0,0). Dim oSketchedSymbol As SketchedSymbol = oSheet.SketchedSymbols.Add( _ oSketchedSymbolDef, _ oTG.CreatePoint2d(0, 0), _ (3.14159 / 4), _ 0.75, _ sPromptStrings) End Sub
The sample VB .NET project is attached.
