Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Running a VBA macro with a password from the AddIn (VB.NET)?
1 REPLY 1
filat
615 Views, 1 Reply
Macros(VBA) can be run from the AddIn(VB.NET) using the code:
Dim invVBA As InventorVBAMember
invVBA = m_inventorApplication.VBAProjects.Item(1).InventorVBAComponents.Item("Module№").InventorVBAMembers("Sub№")
invVBA.Execute()
 But I encountered such a problem that if the macro password is set, the program Adin does not work until manually until shalt bring the password in the VBA ...
Is there a way to separate these processes, so that the macro with the password can be run from the AddIn?
1 REPLY 1
Vladimir.Ananyev
in reply to: filat
This problem is not Inventor API related.
Hope the following links could clarify the situation a little bit:
http://stackoverflow.com/questions/16174469/unprotect-vbproject-from-vb-code
http://www.pcreview.co.uk/threads/programmatically-open-locked-vbaproject.3371133/
http://stackoverflow.com/questions/24804329/open-password-protected-vba-project-programmatically
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
