I haven't marked my last answer as solved yet, since I'm not sure it's solved. I'm getting a run-time error 91 on this code and I'm not sure why. Does anyone have any ideas? I'm thinking it might be related to the Inventor aspect, not the general code. I put the place of the error in bold, underlined, italics, and in red font.
Option Explicit Public i As Integer Public Function ReplaceComponent() Dim NameStr As String Dim NewNamePath As String Dim NameStr2 As String Dim OldNamePath As String NameStr = Renamer.New_Name.Text NewNamePath = Renamer.Path_Text.Text & "\" + NameStr & "-" & Right("00" & i, 3) & ".ipt" NameStr2 = Renamer.Old_Name_Display.Text OldNamePath = NameStr2 & "-" & Right("00" & i, 3) & ".ipt" Dim oOccurrence As ComponentOccurrence Set oOccurrence = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.OldNamePath oOccurrence.Replace NewNamePath, True Do While i < 99 i = i + 1 Loop End Function
This code has an error. It will not give you the occurence with the old name. To get that you would need to:
Sub ReplaceComponent()
For i = 0 To 99 Step 1
For Each oOcc As ComponentOccurrence in ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
If oOcc.ReferencedDocumentDescriptor.FullDocumentName = OldNamePath Then
Set oOccurrence = oOcc
Exit For
End If
Next oOcc
'Then you can replace
Next i
End Sub
This will loop through the Occurrences in the document and when it finds a match to OldNamePath it sets a reference to the occurrence and exits the loop. After replace all occurences with the new path.
Edited to show in context of full subroutine.
This returns an "Expected : In" error
Thank you so much for helping with this 🙂 I really appreciate it. I'm very excited to be almost done with this project!!!
Updated code, with strikethrough through portion that needs to be deleted. Now I'm getting an oOcc not defined message. Baby steps!
For Each oOccAs ComponentOccurrenceIn ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
Exit For
End If
Next oOcc
Next i
End Sub
Here's the iLogic code to do what you want. It will prompt you for the name portion to replace in the file names to rename them.
Create a new iLogic rule and paste this code into it.
Imports System.IO Sub Main() 'Check to make sure this is an assembly document If Not ThisDoc.Document.DocumentType = kAssemblyDocumentObject Then MessageBox.Show("Must run from an assembly") Exit Sub End If Dim oldName As String Dim newName As String 'Get Portion of name to replace oldName = InputBox("Enter the old name:", "Replace References", "") 'Get new name to replace old portion with newName = InputBox("Enter the new name:", "Replace References", "") 'Check to make sure you have an old and new name portion If String.IsNullOrEmpty(oldName) Or String.IsNullOrEmpty(newName) Then MessageBox.Show("Must enter an old and new name") Exit Sub End If Dim occRef As ComponentOccurrence 'Begin Replacing ReplaceRefs(ThisDoc.Document.ComponentDefinition.Occurrences, oldName, newName) End Sub Sub ReplaceRefs(curOccs As ComponentOccurrences, oldName As String, newName As String) 'Loop Through All Occurrences in Assembly For Each oOcc As ComponentOccurrence In curOccs 'If SubAssembly Replace its SubComponent If oOcc.SubOccurrences.Count > 0 Then ReplaceRefs(oOcc.SubOccurrences, oldName, newName) End If 'Check to make sure occurence is not a virtual part If Not oOcc.ReferencedDocumentDescriptor Is Nothing Then Dim fullName As String Dim oldFileName As String Dim newFileName As String Dim filePath As String Dim newFullName As String 'Get Current Occurrence FileName fullName = oOcc.ReferencedDocumentDescriptor.FullDocumentName 'Get Directory Location of File filePath = System.IO.Path.GetDirectoryName(fullName) 'Get Old Filename oldFileName = System.IO.Path.GetFileName(fullName) 'Check to see if old name contains portion Match If oldFileName.Contains(oldName) Then 'Replace old portion with new portion newFileName = oldFileName.Replace(oldName, newName) 'Create new Full FileName. (Assumes new file is in the same location as old file) newFullName = filePath & "\" & newFileName 'Try and Replace with new file Try oOcc.Replace(newFullName, True) Catch 'Show or Collect files that couldn't be found. 'MessageBox.Show("Could not find file: " & newFullName) End Try End If End If Next oOcc End Sub
If only "oOcc" could work, I could modify it for my project! Thanks so much for that!
Take out the portion that has the striked out portion. As ComponentOccurrence.
I did. It opened Pandora's Box. I get all kinds of fun runtime and new for errors and variable not defined errors now 🙂
