Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Run a rule after a "user parameter" is changed
2 REPLIES 2
^_^clovis^_^
1191 Views, 2 Replies
Hello All
I'm trying to use iLogic to modify a pipe.
I have a "user Parameter"
"DN" = 0
I've made a new Rule
"Dimension"
containing
If Parameter("DN") = 8 Then
    Parameter("d14") = 13.5   ' dimension on sketch
    Parameter("d13") = 2.3     ' dimension on sketch
end if
Is it possible to run the rule when the "user Parameter" is modified? and how?
2 REPLIES 2
bretrick30
in reply to: ^_^clovis^_^
You can set an Event Trigger to tell your rule to run on Any Parameter Change.
Manage Tab > iLogic Panel > Event Triggers
Or Instead of using Parameter("DN"), just use the parameter name.  If you just use the parameter name, the rule will run whenever any of the parameters in the rule are changed.
^_^clovis^_^
in reply to: bretrick30
Thanks a lot!
