Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Showing results forĀ
Did you mean:Ā
Rule to suppress features containg certain word
5 REPLIES 5
fakeru
481 Views, 5 Replies
Hi
Would it be possible that a rule can suppress all part's features that contain in their name a certain word.
I use to rename features for better workflow. More features that form a part of the model can contain same word, for instance "foot": foot_extrusion; foot_plate and so on.
When working with ilogic I have to specify each feature name, but I was thinking that may be would be easier to suppress the features by their name.
Alexandru
Autodesk Inventor 2015 Certified Professional
5 REPLIES 5
rossano_praderi
in reply to: fakeru
Hi Alexandru,
this piece of code che be your solution...
Sub Main
	Fsuppress(True)
	Fsuppress(False)
End Sub
Private Sub Fsuppress(suppress As Boolean)
myparam = InputBox("Feature Name", "Feature suppress", "")
If myparam <> "" Then
	Dim oDoc as PartDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oFeature As PartFeature
	For Each oFeature In oDoc.ComponentDefinition.Features
		If oFeature.Name.ToUpper.Contains(myparam.ToUpper) Then
			oFeature.Suppressed = suppress
			oDoc.Update
		End If
	Next
End If
End Sub
 Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
fakeru
in reply to: rossano_praderi
Thank you, this is almost what I wanted.
The difference is that, I don't need the input window.
For example I want a rule when it will be run to suppress al features with "nozzle" word in their name.
I tried to adapt the code, but didn't manage šŸ˜ž
rossano_praderi
in reply to: fakeru
Hi Fakeru, let me know if this is helpful to you.
myparam = "YOUR TEXT"
	oFeature.Suppressed = True
	oDoc.Update
  End If
Next
Bregs
Rossano Praderi
fakeru
Yes, it works! Thank you so much!
rossano_praderi
in reply to: fakeru
You are welcome.
