How do you sort(Resort) a hole table via code? The hole table does not appear to have a .Resort member.
I would think it would be oHoleTable.Resort.
Solved by ekinsb. Go to Solution.
The functionalty to re-sort a table is missing from the API and if it was there it would be exactly where you were looking. I did come up with a workaround that you can see if it will work in your case. This executes teh re-sort command, just the same as if you run it from the user-interface. Since it's a contextual command it relies on the table to sort being selected.
Public Sub ResortTable() Dim drawDoc As DrawingDocument Set drawDoc = ThisApplication.ActiveDocument Dim currentSheet As Sheet Set currentSheet = drawDoc.ActiveSheet ' Get the hole table to sort. Dim table As HoleTable Set table = currentSheet.HoleTables.Item(1) ' Add it to the select set. drawDoc.SelectSet.Clear Call drawDoc.SelectSet.Select(table) ' Get the re-sort command and execute it. ThisApplication.CommandManager.ControlDefinitions. _ Item("DrawingHoleTableResortCtxCmd").Execute End Sub
Your code worked great. Thanks Brian.
Hi Brian,
I have the same issue with a lack of column sorting in the hole table, found your article, copied in your ilogic, but nothing happened. I did not see any new opportunity to sort in any of the commands in the hole table. We're running the 2014 version of Inventor. Not sure if anything in your routine needs to be updated as your comments were posted back in 2013, but please let me know if you have any suggestions or updates to the code to make sorting available in the hole table data.
thanx
Rob
I just tested this again with Inventor 2015 and it works just the same as it did before. The original samples was VBA and you mentioned iLogic. Below is the code converted to an iLogic rule and that is also working.
Dim drawDoc As DrawingDocument drawDoc = ThisApplication.ActiveDocument Dim currentSheet As Sheet currentSheet = drawDoc.ActiveSheet ' Get the hole table to sort. Dim table As HoleTable table = currentSheet.HoleTables.Item(1) ' Add it to the select set. drawDoc.SelectSet.Clear drawDoc.SelectSet.Select(table) ' Get the re-sort command and execute it. ThisApplication.CommandManager.ControlDefinitions.Item("DrawingHoleTableResortCtxCmd").Execute
