Just trying to maximise the use of all iProperties but there are certain iProperties that I'm unable to update via iLogic.
So far the first four I am unable to change are
"Eng Approved By"
"Eng Approved Date"
"Mfg Approved By"
"Mfg Approved Date".
I was hoping there would be some form of reference sheet as the snippets panel only list a few of the very basics.
I've tried the following with no success, I just get a non-existent iProperty error.
iProperties.Value("Status","Eng Approved By")
Solved by MjDeck. Go to Solution.
You have to include the dot after Eng or Mfg. This is the same as shown in the iProperties dialog. Examples:
iProperties.Value("Status", "Eng. Approved By") = "Me"
iProperties.Value("Status", "Eng. Approved Date") = New DateTime(2010, 10, 31)
iProperties.Value("Status", "Mfg. Approved Date") = Now
I could have sworn I tried that, Cheers it worked!
Is there a reference sheet by any chance? or a guide that covers most topics relating to iLogic?
There's no reference sheet for the iProperties. The best help is in the Inventor 2011 Help under
Autodesk Inventor -> iLogic -> Functions -> Quick Reference -> iProperties functions
This should also be available on http://wikihelp.autodesk.com (although this site is down for maintenance right now).
