Inventor Customization
Distinguished Contributor
10 Kudos
Post 1 of 6
Replace styles in Drawing
454 Views, 5 Replies
08-24-2012 02:52 AM
Hi
I have some styles I will like to replace in some drawings
but how? I cant find any function to do this.
Do I missing some thing ?
Dim oIDWStyles As Inventor.DrawingStylesManager
 Set oIDWStyles = oDrawDoc.StylesManager
 Dim oldstyle As style
 Dim Newstyle As style
   For Each oldstyle In oIDWStyles.Styles
     If oldstyle.Name = "Old style" Then
       '  Debug.Print oldstyle.Name & " : " & oldstyle.InternalName
        For Each Newstyle In oIDWStyles.Styles
          If Newstyle.Name = "New style" Then
            'Debug.Print Newstyle.Name & " : " & Newstyle.InternalName
            End If
        Next
        'How to replace oldstyle with newstyle
         'oldstyle = Newstyle
     End If
   Next
René J
1 Kudo
Post 2 of 6
Re: Replace styles in Drawing
08-24-2012 05:31 AM in reply to: Rene-J
This worked for me:
' Create the parts list and set a reference to it.
    Dim oPartsList As PartsList
    Set oPartsList = oSheet.PartsLists.Add(oDrawingView1, oPlacementPoint)
    oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PARTS LIST PART")
Hope this helps.
Chris
106 Kudos
Post 3 of 6
08-24-2012 05:43 AM in reply to: Rene-J
You can rename it, delete it, set another style as the object default, but no direct replace that I know of.
If you set the new styles as object defaults, then you could change all elements to the active standard.
Jonathan D. Kriek
Manufacturing Solutions Engineer
KETIV Technologies, Inc.
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
1 Kudo
Post 4 of 6
08-24-2012 05:57 AM in reply to: jdkriek
UGHHHH....I swear I read "parts list style" the first time I read your post!  Thats what I get for responding before I've had some caffeine!
106 Kudos
Post 5 of 6
08-24-2012 06:04 AM in reply to: cmines
Get some coffee, it will be alright - for a Friday :smileywink:
Jonathan D. Kriek
10 Kudos
Post 6 of 6
09-05-2012 08:59 AM in reply to: jdkriek
Thanks Jonathan
Finally I got the time, to look at your suggestion.
I'm sorry I have not commented earlier, I've been on vacation.
I thought there was an easier solution.
René J
