Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
renumber partlist
2 REPLIES 2
GeorgK
321 Views, 2 Replies
renumber partlist
Hello together,
how could I renumber my partlist at a given position for example 50 to 100?
First I renumber it :
Call oBOMView.Renumber(1, 1)
1-50
50-100  => 500-1000
Thank you very much
Georg
2 REPLIES 2
YuhanZhang
in reply to: GeorgK
Can you explain more details about your requirement? I created a VBA sample for your requirement, not sure if this can satisfy you:
Sub RenumberPartslistSample()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    ' In UI select a part list first
    Dim oPL As PartsList
    Set oPL = oDoc.SelectSet(1)
    ' Set which rows will be renumbered, like rows from 50 to 100
    Dim iStart As Integer, iEnd As Integer, sInput As String
    sInput = InputBox("Input the start row number for renumbering", "Input data")
    iStart = CInt(sInput)
    sInput = InputBox("Input the end row number for renumbering", "Input data")
    iEnd = CInt(sInput)
    ' Set the start value for the renumbered rows and step value
    Dim iRenumStartValue As Integer, iRenumStepValue As Integer
    sInput = InputBox("Input the start value for renumbering", "Input data")
    iRenumStartValue = CInt(sInput)
    sInput = InputBox("Input the step value for renumbering", "Input data")
    iRenumStepValue = CInt(sInput)
    Dim oRow As PartsListRow
    Dim i As Integer: i = 1
    For Each oRow In oPL.PartsListRows
        If i > iStart - 1 And i < iEnd + 1 Then
            oRow.Item("ITEM").Value = iRenumStartValue + iRenumStepValue * (i - iStart)
        Debug.Print oRow.Item("ITEM").Value
        i = i + 1
    Next
    oSheet.Update
End Sub
 Please let me if this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
GeorgK
in reply to: YuhanZhang
Hello Rocky,
thats exact what I am looking for.
Thank you very much
Georg
